tks
| posted on 6/10/06 at 07:12 AM |
brake balance
Hi guys i have got a velocity XT and i have a brake balance bar, apart that i don´t untherstand very very well how to mount it all up, i wanted to
know if the both MC´s are of the same size?
Does anyone know if luego sells both MC´s the same size?
or does the rears is smaller?
Also is it true that to mount the balance bar i need to take of the MC´s, put on the balance bars the alloy pieces! just at the center distance of
both pistons!
and then put the mc thru the hole and turn it in the thread??
i have it now mounted but i can see with the eye that they aren´t center...
also how easy could the girling mc leak liquid?
Thanxs allot..
Tks
roadboy
| posted on 6/10/06 at 07:35 AM |
Larger m/cyl to the rear brakes as they need less effort. Assemble as you said but adjust the pushrods so the bar is at 90 degrees to the pedal with
the brakes applied 50%.
HTH
Ian
Jude Performance Services
NS Dev
| posted on 6/10/06 at 08:32 AM |
you want a 5/8" cyl for the front and a 3/4" cyl for the rear, as a start point, most sevens should work with this setup and a balance bar
Dusty
| posted on 6/10/06 at 09:28 AM |
The Rally design website has some Tech Tips in the top right of the page including some drawings of setting up a balance bar.
Link here.
tks
| posted on 6/10/06 at 09:37 AM |
mhhh
i see on the pictures that there is a nut on the cilinder pushrod
i´m 100% sure my MC doesn´t have them. They only are screwed in the blansbar thingy...
can anyone send me 2 nuts? (they are UNF) and cant be brought here
will paypall the money for beer tokens
Tks
p.d. this end of week will be balance bar weekend i guess..
