Author: Subject: what ratio is this diff?
rotax78
posted on 7/10/06 at 02:49 PM Reply With Quote
Hi I think that i have a xr4x4 lsd how can i tell? and how can i find out what ratio it is? there is some kind of aluminium tag attatched to it, but i can't get to it at the min. is there anywhere that has a chart or something to identify the numbers on the tag. cheers simon
mistergrumpy
posted on 7/10/06 at 02:53 PM Reply With Quote
If you do a search there's a list somewhere of the ratios according to a letter on the cars chassis plate.
This should help.
[Edited on 7/10/06 by mistergrumpy]
Tangerine Scream
posted on 7/10/06 at 03:44 PM Reply With Quote
Turn a rear wheel.
If other rear wheel turns same way, you have an
LSD.
If it goes the other way, you don't.
givemethebighammer
posted on 7/10/06 at 04:22 PM Reply With Quote
any use ?
wheezy
posted on 7/10/06 at 04:38 PM Reply With Quote
Originally posted by Tangerine Scream
Turn a rear wheel.
LSD.
Dont forget to hold the input coupling or only the wheel you are turning and the input coupling will move
Dave
Tangerine Scream
posted on 7/10/06 at 04:41 PM Reply With Quote
Thanks Dave
Knew I'd forget something
rotax78
posted on 8/10/06 at 05:42 PM Reply With Quote
many thanks chaps, i do have an lsd 3.62 is the suitable for a bec
DIY Si
posted on 8/10/06 at 05:55 PM Reply With Quote
Yes. What engine are you planning on using? The 3.34 and the 3.14 are also suitable. Also remember that the lsd is 7kg heavier than an open diff.
Sun Tzu, The Art of War
