Author: Subject: Shocker Lengths
mistergrumpy
posted on 7/10/06 at 05:59 PM Reply With Quote
Shocker Lengths
Okay I've been searching but can't reall find anything, can't sem to word it right I think. What I'm after is the length of the shockers I need for standard chassis with GTS front bones and De Dion. Or how do I figure out what I need?
rayward
posted on 7/10/06 at 06:15 PM Reply With Quote
set your chassis up at the desired ride height, then measure the distance bewteen the shocker mounting bolt holes, get shocks that range approx 1- 2" either side of that figure.
hth
Ray
[Edited on 7/10/06 by rayward]
mistergrumpy
posted on 7/10/06 at 06:19 PM Reply With Quote
Ah right. Thought there was something more complicated to it than that.
posted on 7/10/06 at 06:49 PM Reply With Quote
shocks usually are specified by their open length, and as ray says, you want about 4 inches of travel at the wheel (3" on the shock will give 4 at the wheel due to the angles). Hence if the length is 10.5" when the bones are level, get shocks that are 12" open.
mistergrumpy
posted on 7/10/06 at 09:31 PM Reply With Quote
Cheers Joel. Appreciated.
flak monkey
posted on 8/10/06 at 07:24 AM Reply With Quote
Std GTS shocker lengths are:
Front: 12" open, 11.25" ride height and 10" closed
Rear: 11.5" open, 10.5" ride height and 8.5" closed
Sera
http://www.motosera.com
mistergrumpy
posted on 8/10/06 at 09:37 AM Reply With Quote
Thanks David. That helps. Was thinking of buying in advance you see as there seems to be a lot on EBay at the moment.
