andrews_45
| posted on 8/10/06 at 04:10 PM |
What track rod ends?
I have a mk2 escort steering rack and cortina uprights. I ordered a new set of track rod ends for the rack, I ordered standard mk2 escort ones. They
do not fit into the tina uprights.
The cortina uprights do not have a tapered hole, but the escort track rod ends have a tapered location shaft of a bigger diameter. Any help much
appreciated
Ta
flak monkey
| posted on 8/10/06 at 04:11 PM |
Std mk2 track rod ends are the ones to use and the tapers are the same.
You know they go in from the bottom of the steering arm on the upright, right?
Sera
http://www.motosera.com
t.j.
| posted on 8/10/06 at 05:06 PM |
I've always concluded that the cortina Mk?/ Taunus Mk3 ones are the same as the escort MK2 ones.
I'm planning to use the cortina ones as the fit.
Mark Allanson
| posted on 8/10/06 at 05:19 PM |
appreciated
Ta
Cortina uprights DO have tapered Rod end holes, sounds to me that you may be trying to put them in from the top instead of the bottom. The Tina Mk5
and Escort Mk2 rod ends are exactly the same
andrews_45
| posted on 8/10/06 at 05:26 PM |
classic!!! ta chaps, I were trying to fit them from the top...Good job I decided to call it a day, before I did summat really silly like drill them
out
| posted on 9/10/06 at 09:25 AM |
out
