Author: Subject: Diff vent pipe
Indymike
posted on 10/10/06 at 01:23 PM Reply With Quote
Diff vent pipe
Diff vent pipe: what is it? What does it do? Do I need one?
My Sierra diff seems to have come without this, but I see it on lots of pictures from other builds. Mine does have a small black plastic cap on top of the diff and it looks like there was once something attached to it but it must have broken of.
So am I missing something important?
Build manual? What build manual?
zxrlocost
posted on 10/10/06 at 01:52 PM Reply With Quote
just a little piece of rubber tube about 4 inches long will do just fine fitted to that nipple and thats it
Hammerhead
posted on 10/10/06 at 01:54 PM Reply With Quote
nipple
Indymike
posted on 10/10/06 at 02:22 PM Reply With Quote
Problem is that the part of the nipple that holds the tube is broken of.
zxrlocost
posted on 10/10/06 at 02:24 PM Reply With Quote
wont hurt as long as you can get the pipe on
otherwise just leave it
mookaloid
posted on 10/10/06 at 03:12 PM Reply With Quote
My diff needs a tube about a foot long otherwise it chucks oil out all over.
I can't imagine doing without will keep all the oil in.
The 'nipple' is only a plastic push in thing I guess it would only be coppers from ford.
mark
C10CoryM
posted on 10/10/06 at 03:35 PM Reply With Quote
Diff vents just vent the pressure from the expanding gasses as the diff fluid heats up and keeps the dirt/water out. Otherwise the pressure will blow out the axle seals.
Some are just a little tube with a loose cap on it, and some are hoses that go up and curve down to keep the water out.
Seems a little odd you are losing a lot of oil out yours mookaloid, is it right above the ring gear or something?
"Our watchword evermore shall be: The Maple Leaf Forever!"
mookaloid
posted on 10/10/06 at 03:46 PM Reply With Quote
It's in the standard place - maybe I just drive mine harder
RichieC
posted on 10/10/06 at 04:26 PM Reply With Quote
The vent pipe is still available from Ford fo about 60p, mine was the same when it came.
indykid
posted on 10/10/06 at 04:29 PM Reply With Quote
fwiw, mine chucked oil everywhere too.
i put a long bit of pipe on and cable tied it to the wishbone bracket. no oily mess after that.
tom
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 10/10/06 at 06:40 PM Reply With Quote
Diff Vent
Mine lost a bit of oil (and it was filled with the correct amount) so a long tube was fitted.
I also put a fuel filter (one of the push on plastic ones) on mine as I was worried about dust etc getting in the diff.
John
Indymike
posted on 10/10/06 at 07:03 PM Reply With Quote
Thanks guys,
I'll be off to the local Ford tomorrow to get a new nipple and pipe then!
RichieC
posted on 10/10/06 at 07:12 PM Reply With Quote
Its just one bit. The cone end presses into the diff so you might have a bit of a wiggle to get the old one out.
