tks
| posted on 11/10/06 at 09:58 AM |
brake balance bar adjustment values? Clues?
HI guys this one i realy simple...
need to set it up, how do i know if its right settedup
Sow how can i test if it does what mr rva wants to see? (and me offourse).
wats the reason that many people like to readjust after sva..
thanxs!
Tks
smart51
| posted on 11/10/06 at 10:04 AM |
One simple test is to drive at progressively higher speeds and apply the brakes hard. If the rears lock up before the fronts then there is too much
rear bias. Do it slowly first as the car can spin if there is too much rear brake force.
tks
| posted on 11/10/06 at 10:14 AM |
mhhh
isn´t there any clue on how much KN i should have with a weight??
balance % values??
[Edited on 11/10/06 by tks]
Agriv8
| posted on 11/10/06 at 10:33 AM |
the values are worked out by the SVA man on a spreadsheet.
paramaters are axle weights and ride high comes into play.
the car is tested by the examiner who measures brake forces on the pedal and wheels from his machine.
though I am sure it would be possible to do at home it could be difficult to get spot on.
most examiners will be happy to test advise re-setting and try again when succesfully completed they will probably want the bias bar 'locking of
could be wrong though.
regards
agriv8
tks
| posted on 11/10/06 at 10:38 AM |
mhhh
problem is that i need to set it up in town with a brake meter in a garage.
on the rollers..
i cant drive the car to much if they grab me i wont have any car anymore!!
Tks
JB
| posted on 11/10/06 at 04:54 PM |
Brake Balance Adjustment In The Garage
As a starting point I use the following method........
Jack up the car with the wheels on.
Get someone to press the brake pedal so you can just not turn the front wheels. Without changing the brake pressure you should just be able to turn
the rear wheels.
Then you need to get on the road and fine tune. The problem is you will require different bias for different grip conditions.
John
tks
| posted on 11/10/06 at 05:30 PM |
mhhh
cant no body pullout the SVA manual?
and come with some vallues??
and calculations..
Tks
Uphill Racer
| posted on 13/10/06 at 11:25 PM |
Yep J B I do it that way 2............Why wasnt u at 3 sisters 4 the last sprint............it was a good day
