Humbug
| posted on 15/10/06 at 09:04 PM |
Could anyone make a steering wheel spacer for me?
The ongoing saga... I need my wheel closer to my chest so I have looked at a number of things. Re-reading an earlier post, it looks like the simplest
thing would be to get a spacer for the boss... except that I can find one ready made.
Does anyone have the materials (chunky bit of ali) and tools (probably a lathe and a drill press to make me something?
I am basically after a disc of ali say 40-50mm thick, 87mm wide with a 40mm hole through the centre. Ideally I also need the other holes drilling as
well, but I am guessing (hoping) that those wouldn't be so difficult to do with a normal drill.
If anyone can help, please U2U or email me with info and an idea of cost.
[Edited on 15.10.2006 by Humbug]
Humbug
| posted on 15/10/06 at 09:27 PM |
quote: Originally posted by CaLviNx
Hi
No lathe needed just time and effort. a trip to local steel scrappie a rummage around take a bit of 2mm flat plate(mild steel will do) scribe two
rings on it cut out with jigsaw drill holes on each ring to suit both wheel & boss, you have your end plates done, & look for a bit of steel
tube of a suitable dia, cut to the required length MiG the end rings to the tube, viola your extender is done.
no lathe needed... just a welder, which I don't have, and welding skills, which I don't have, either unfortunately
Humbug
| posted on 15/10/06 at 09:30 PM |
quote: Originally posted by hicost
I have a Myford super 7 in the garage and many other tools. You are welome to come over and I will turn one down for you. I am in West Sussex RH123TH
just outside Horsham.
James
Thanks - that sounds like a possibility. Could you U2U or email your phone number so we could have a chat about it?
russbost
| posted on 15/10/06 at 09:31 PM |
You can buy these from Demon Tweeks - Surely??
RazMan
| posted on 15/10/06 at 09:35 PM |
How about a quick release boss? It will give you about 60mm IIRC
Raz
Humbug
| posted on 15/10/06 at 09:38 PM |
... Spacers not available from Demon Tweeks for Mountney traditional style wheels, as far as I could see
... quick release boss is not very locost
Thanks for the various replies though
RazMan
| posted on 15/10/06 at 09:59 PM |
Oooh I don't know
http://cgi.ebay.co.uk/D1-SPEC-Quick-Release-Snap-off-Boss-Kit-Universal_W0QQitemZ120041225293QQihZ002QQcategoryZ40195QQssPageNameZWDVWQQrdZ1QQcmdZView
Item
[Edited on 15-10-06 by RazMan]
Raz
| posted on 15/10/06 at 10:12 PM |
This one.
ebay item .
What kind of column have you used. I got mine closer by undoing the alloy mount clamped round the convoluted section and pulling it further through
  Steering column mount
This was what mine looked like.
Mark Allanson
| posted on 15/10/06 at 10:24 PM |
Make your own, the mounteny boss you have will not pass SVA without a fair bit of modification. I cut the ford one out of the original wheel and made
a deformable boss, bolted to the upper mount ring of the original mountney boss.
Humbug
| posted on 16/10/06 at 05:46 AM |
Thanks again for the further info
ebay quick release boss looks OK
Might try moving the column nearner
Standard Mountney boss passed SVA OK no problem!
GaryM
| posted on 16/10/06 at 07:23 AM |
Check out http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?act=ST;f=8;t=42548
It looks he can supply blanks.
Gary
Humbug
| posted on 16/10/06 at 08:00 AM |
Gary
tried him - seems the mountney ones are too big
| posted on 16/10/06 at 08:08 AM |
rally design or buton power do a cllapsible spacer thing. looks like two disc and between them are 4 angled plates.
I don't think the pcd is comaptible with mountney boss but I have another disc to adapt between the two.
Humbug
| posted on 16/10/06 at 08:38 PM |
ebay item .
Problem solved (and at zero cost)! Thanks... I didn't realise the column could be pulled through the clamp thingy, as I bought my car as a
rolling chassis with the column already fitted.
