andrews_45
| posted on 22/10/06 at 01:41 PM |
Mounting sierra steering column
When I stripped my Sierra I forgot to remove the steering column bracket, does anybody have details of how theirs is mounted? Pics would be great.
Ta
big_wasa
| posted on 22/10/06 at 01:54 PM |
This is how I did mine. Doesnt mean its corect tho
Mark Allanson
| posted on 22/10/06 at 02:03 PM |
Is this what you are looking for?
mark chandler
| posted on 22/10/06 at 05:36 PM |
Not to be out done, here's my attempt, again it does not mean its correct, welded nuts into the tube and washers to spread the load.
I sat in the car and held the wheel where I wanted it to determin the hieght distance from driver.
andrews_45
| posted on 23/10/06 at 08:59 PM |
Thanks a lot chaps, I can see I am missing summat, I aint sure wht is called. I'll take some pics tomorrow during daylight...
andrews_45
| posted on 24/10/06 at 04:42 PM |
This is all I have, I am sure I have summat missing
Mark Allanson
| posted on 24/10/06 at 06:16 PM |
You are missing the column lower mount
| posted on 24/10/06 at 06:17 PM |
You've only got the column inner from an adjustable column there, looks like a trip to the scrapyard for you .
[Edited on 24/10/06 by Peteff]
Mark Allanson
| posted on 24/10/06 at 06:19 PM |
Inner and outer are only pennies from Ford
| posted on 24/10/06 at 07:52 PM |
If you can find a piece of tube the right size for the nylon bush to push into you can use that. Robin Hood do a bearing and a plate ready cut to fit
it into, drill it and bolt it on or weld it into place. Plate and
Bush kit and put a jubilee clip round the triangular bit to stop them riding
up the column.
andrews_45
| posted on 25/10/06 at 05:57 PM |
Pete, that looks a very good idea. Is that what you have done? if so can I see a pic or sketch please to see what to do?
Ta
Danozeman
| posted on 25/10/06 at 07:12 PM |
Looks like your missing the top mount to.
Dan
