Author: Subject: When I grow up...
posted on 31/10/06 at 09:27 AM Reply With Quote
When I grow up...
... I'm gonna be a gynaecologist
In the meantime I've been practicising:
speedo panel
speedo panel
Small panel cut out behind battery to gain access to speedo (cable snapped at speedo head!) - after some fiddling, managed to undo the nuts and the speedo is out.
Eventualy will have a DC motor to drive the speedo to compensate for speedo drive/speedo mistmatch and be programmable for different wheels sizes.
Surrey Dave
posted on 31/10/06 at 11:05 AM Reply With Quote
Easy???
Must be easier just to fit an electronic speedo , Racetech £60 ish , calibrated by one control on the back..............
posted on 31/10/06 at 11:27 AM Reply With Quote
more like £ 120 minimum-ish be interested where you can get one for that much.
Anyway, it will be an excuse to use a PIC.... at last.
and whilst I am still here, anyone know what speedo cable I should use - the speedo head has an 18 mm threaded part that the cable must screw onto - I take it that is not a Ford fitting? (but of not Ford cable, it won't fit in the gearbox).
[Edited on 31/10/06 by 02GF74]
Dusty
posted on 31/10/06 at 11:45 AM Reply With Quote
Talk to http://www.speedycables.co.uk/ who will make whatever length of cable with whatever end fittings you want for about the same price as a main dealer will supply a standard one.
zoom
posted on 31/10/06 at 01:06 PM Reply With Quote
Hi what sort of crank breather is that?..... looks like a coke tin..............
mycar
mybuildsite
Surrey Dave
posted on 31/10/06 at 01:24 PM Reply With Quote
£81
£81 built mine in 1999/2000 that's inflation
http://www.merlinmotorsport.co.uk/INSTRUMENTS-RACETECH-Electrical-Gauges/c1_354_356/index.html
You can pay £40 + just for a right angle cable drive..............
[Edited on 31/10/06 by Surrey Dave]
posted on 31/10/06 at 01:45 PM Reply With Quote
A coke tin made by KitKat
[Edited on 31/10/06 by MikeRJ]
no, it is very expensive tank from Satanic Tweaks. A kit kat tine, I;ve eatne them all so don't ask, with a drain tap in the bottom; two pipe soldered to the top for the inlet and mini air filter. The only not perfectthing is the insulation tape to hold the lid on down - still working on how to address that.
nice 'n' locost!
