Author: Subject: Ignition Coil
Kook
posted on 30/11/06 at 05:57 PM Reply With Quote
Ignition Coil
Can I use any 12 volt coil or does it have to be a ford one for my Pinto engine ?
flak monkey
posted on 30/11/06 at 06:03 PM Reply With Quote
Depends on whether or not you have points or electronic ignition and if you have a ballast resistor or not.
More info required
Sera
http://www.motosera.com
Kook
posted on 30/11/06 at 06:06 PM Reply With Quote
Its dizzy with points ... Not sure what you are o n about with Resistor ... am in over my head
flak monkey
posted on 30/11/06 at 06:09 PM Reply With Quote
You need to measure the voltage at the coil on the positive side, if its 9v you have a ballast resistor, if 12v you dont.
You need to make sure you get a coil designed for a points dizzy, an electronic ignition one will work, but will wreck the points pretty quick.
Sera
posted on 30/11/06 at 09:32 PM Reply With Quote
If there is no coil present he will get 12v irrespective of wether a ballast resistor is used or not.
DarrenW
posted on 30/11/06 at 10:43 PM Reply With Quote
Have you considered fitting electronic ignition to get rid of the points all together. Ive just listed a full complete electronic system that is easy to fit - all oem ford stuff. Ive got exactly the same set up on mine at the moment and it works a treat. Just fit and forget.
