Jon Ison
| posted on 3/12/06 at 10:06 PM |
Dilemma ?
I have a nice pair of alloy double adjustable shocks, been in garage ages never used em...........
Trouble is there a tad short too fit so do I just clean up and paint the old ones during the rebuild or bite the bullet and fabricate and weld on new
brackets too the chassis, only sticking point is I would have too ease off the front bodywork too weld the new upper brackets on without causing
damage too the bodywork (side panels)
Other option is sell em.
tegwin
| posted on 3/12/06 at 10:11 PM |
Have you considered buying or making longer eyelets so they will actually fit?
RichardK
I think you should sell em to me for a tenner
Rich
Gallery updated 11/01/2011
Jon Ison
| posted on 3/12/06 at 10:15 PM |
Rich
you can have the perfectly good old ones that may come off for £50 if you want, including springs.
Adjustable platforms with single adjustment on the damping.
Cant go for different eyelets, there one piece alloy body and eyes with rose joints.
tegwin
| posted on 3/12/06 at 10:18 PM |
The eyelet on the end of the piston has to come off somehow....
Jon Ison
| posted on 3/12/06 at 11:02 PM |
Correct but as one of the two adjustments is done thru a hole the eyelet with a 2mm allen key new ones would cost a fortune, hence much cheaper too
make new mounts. Here is the bottom.
procomp
| posted on 5/12/06 at 07:53 AM |
Hi jon have you cheked to see if they make longer top eyes for them or is the extra lenght to much for that.
cheers matt
(edit) Or if you wanna bring the old and new down i will run them on the dyno for you so you can see if you need to change them or if the new are
suitable for the car as i did say i would do this for you on the race car.
[Edited on 5/12/06 by procomp]
