ceebmoj
| posted on 6/12/06 at 01:14 PM |
Converting live axle to disks
Hi all,
I think that my car has and English axle and I wanted to convert it to disks from drums. My questions are what do I need and how do I correctly
identify the axle?
blake
dozracing
| posted on 6/12/06 at 01:39 PM |
Easiest way is to contact Rally Design and buy a kit of parts off the shelf.
DG
Fatgadget
| posted on 6/12/06 at 01:49 PM |
Chrysler 180 disks fit straight on....If you can still find them.
| posted on 6/12/06 at 02:36 PM |
Fiesta solid front discs fit on the rear with the drum backplates removed. You'll need some callipers like the VW or Pug/Citroen ones and some
brackets either welded on or bolted to the half shaft bearing plate.
russbost
| posted on 6/12/06 at 03:55 PM |
I'd have to ask - why?
Andy S
| posted on 6/12/06 at 05:30 PM |
I have to agree - why? - the conversion to discs just makes the assembly heavier and you end up with a sytem that will be overbraked and need to be
restricted by a bias valve etc.
Only worth while if on a heavy car with poor brakes as standard that you intend to make much quicker.
If you want to upgrade - go for drilling the back plates to add a bit of extra cooling and new grooved drums.
lsdweb
| posted on 6/12/06 at 05:51 PM |
HAve a look here for weights and how to do it.
Wyn
| posted on 6/12/06 at 09:03 PM |
Just use Escort Mk3 1980-86 front non-vented discs very cheap for www.buypartsby.co.uk (less than 6 quide + vat + p&p
Rear Calipers Rover 216 or 416 or VW Golf are about ideal.
| posted on 6/12/06 at 09:07 PM |
In the 1970s they were the only discs that fitted straight over a 4.25" pcd hub but things a have moved on a lot since then, just about any
80s-200 Ford Sierra or Escort disc can be used.
| posted on 6/12/06 at 09:10 PM |
True but the real benefit from rear disc on a Locost is they respond to pedal presure in a similar fashion to the front discs unlike drums which
have a different friction/pressure curve.
| posted on 7/12/06 at 12:11 AM |
New drums are £35 each + backplate + cylinder. If you can get the Golf or Pug alloy calliper with a small disk I don't think there's that
much of a weight penalty, plus disks give a firmer pedal as mentioned.
gazza285
| posted on 7/12/06 at 05:29 AM |
I've yet to find any disc that will fit straight on, most need the half shaft flange reducing in diameter to allow the disc to fit, easy job
though, two minutes on a lathe. I have a pair of brackets for the Citroen/ Pug calipers to suit using the Fiesta/Escort discs if you want them,
straight bolt on job.
NS Dev
| posted on 7/12/06 at 09:56 AM |
same here Gazza, always had to turn a tad off the halfshaft flanges, pretty std mod.
lsdweb
| posted on 7/12/06 at 12:59 PM |
I turned the discs rather than the halfshafts as I worked on the premise that if I ever broke a halfshaft it would be easier to scounge one if it
didn't have to be already machined.
