Author: Subject: Sierra Steering column 'Spring Washer Thingy'
The Doc
posted on 17/12/06 at 10:29 PM Reply With Quote
Hi Folks,
What is the function of that spring washer which is a push fit onto the triangular section of shaft?
Is it meant to prevent the nylon bush riding up the shaft. It doesn't seem a lot use to me.
Does Mr SVA need it?
TA
Mike
meany
posted on 17/12/06 at 10:33 PM Reply With Quote
thats what i thinks its for anyway
indykid
posted on 17/12/06 at 10:35 PM Reply With Quote
i can only assume it is to prevent the bush riding up the shaft. with use, the bush does shimmy up and out of the outer housing giving a wobbly column.
mine didn't really seem to do much either so i replaced it with a big copper washer cut out to fit the triangular shaft and a petrol pipe type clip to stop it all moving. suppose a jubilee would do the same job, but i was worried about it catching the bulkhead.
much more solid now, and no play in the column.
tom
PAUL FISHER
posted on 17/12/06 at 10:37 PM Reply With Quote
Yes,thats what it is there for,the bush will not stay in position without it,you can replace it with a jubilee clip if you want,this is what I used on my last car,in place of the spring washer.
Chippy
posted on 18/12/06 at 12:00 AM Reply With Quote
Drilled a 1/8" hole on one plane of the triangle, and put a roll rin in mine. Hasn't moved since. Ray
posted on 18/12/06 at 11:24 AM Reply With Quote
Nice ickly jubilee clip works much better as mentioned. I think the clip works when first used but during the install my clip became a loose fit so it really didn't do much anymore......
It's probably a Haynes "discard item as a new one will be required anyway" item...
mackei23b
posted on 18/12/06 at 03:46 PM Reply With Quote
I replaced mine with a large steel washer cut out to fit the triangular shaft and tack welded it at three points to the column.
Ian
