Author: Subject: bump steer / steering rack mods
rj
posted on 1/1/07 at 07:34 PM Reply With Quote
Hi , I think it is generally accepted that the book chassis & Escort mk 2 rack causes bump steer, ( I cannot speak from experience yet , my car is not finnished ) , so I have been doing some measurement / thinking . The basic problem is that the rack is too long between inner ball joints, I think it needs to be shortened by about 116 mm .
I think there are 2 ways to do this
1 cut 116mm off n/s end of rack , and remachine thread etc
2 cut 116mm out of middle of rack & rejoin - I was thinking of tapping say M12 and weld round
and cut 116mm out of middle of casing & reweld
then rack will need to be repositioned 58mm to n/s to centre it up, plus longer steering arms
so what do you think ! or has anyone tryed this already ?
stevec
posted on 1/1/07 at 07:37 PM Reply With Quote
you mean like this?
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=2P1010079.JPG
MattCraneCustoms
posted on 1/1/07 at 07:43 PM Reply With Quote
id be interested in doing the same, havent got a rack yet though. Is it difficult to do steve? Thats a nice looking chassis by the way!!
Regards
Matt
stevec
posted on 1/1/07 at 07:46 PM Reply With Quote
The rack was done by MK they didn't charge much.
Steve.
[Edited on 1/1/07 by stevec]
Bob C
posted on 1/1/07 at 07:53 PM Reply With Quote
Number 1 is the answer rj.
It's fairly straightforward - however I did have an issue with an old rack - when shortened the toothed part ended up sliding into the plastic bush the rack runs in at the nearside end & this then broke up. I got a new rack & lock limiting spacers on now (shortened the same way).
For my setup (modified mx5 uprights) I needed to shorten 3.5"
Bob
Fozzie
posted on 1/1/07 at 08:50 PM Reply With Quote
Hmmm I have a 'locost' (book chassis) with MK2 rack and I have never encountered bump steer.
So I cannot definitely say that it will be a problem.......
Fozzie
posted on 1/1/07 at 11:05 PM Reply With Quote
Carefull positioning of the stock rack can minimise bump steer to reasonable levels.
Fozzie
posted on 1/1/07 at 11:12 PM Reply With Quote
Absolutely Mike!
IMHO it is a part of the build where a lot of thought and forward thinking, is a 'must'.
Fozzie
nitram38
posted on 1/1/07 at 11:15 PM Reply With Quote
Basically, if you draw a line between the top and bottom wishbone inboard bushes, your steering rack inner ball joint centre should be anywhere along this line.
In other words, raising or lowering the rack until these are in line.
I don't know how far out a locost rack is so you may have other issues with the track rod end and it's angles.
I made my rack inline with the top wishbone and had a titan rack made with ball joint centres that matched the top bone's inner bushes.
In otherwords, unequal wishbones travel in an arc that trys to keep your tyre patch parrallel to the road surface and your rack must travel in the same parrallel arc to avoid bump steer.
[Edited on 1/1/2007 by nitram38]
DavidM
posted on 2/1/07 at 12:13 AM Reply With Quote
I can't say I've encountered it either.
daviep
posted on 2/1/07 at 12:38 AM Reply With Quote
I shortened my MK2 rack by method 1. Found that I could eliminate bump steer with the standard rack by mounting it a lot higher, but it would have meant machining the taper for the TRE so that it pointed downwards in order to keep the track rods reasonably parrallel with the wishbones.
Davie
zetec7
posted on 2/1/07 at 12:44 AM Reply With Quote
I had a Cevy Chevette rack cut down by 2" - the outer housing was cut in half on a lathe, 2" cut out, then tig-welded back together on the lathe. The rack itself was cut down by cutting off the non-toothed end (by 2", then turning a new threaded tie-rod arm thread onto it. All very professional, and not expensive (about $100 CDN). As to raising and lowering the rack to eliminate bump steer, that will work to some extend, but then you re-create the problem vertically that you'd solved horizontally!
http://www.freewebs.com/zetec7/
Marcus
posted on 2/1/07 at 09:53 AM Reply With Quote
I know it's wrong, but, I lowered my escort rack in the chassis. The thinking being if I can't shorten the rack, make the steering arms as horizontal as possible at normal ride height to minimise the effects of bumpsteer. Now if the suspension is in droop or compression there's a slight amount of toe in on both wheels - so small that you don't notice it.
Marcus
Because kits are for girls!!
Fozzie
posted on 2/1/07 at 10:08 AM Reply With Quote
Originally posted by CaLviNx
Hi
It must be noted that "stevec's"rack looks like its a cut down sierra rack NOT a standard MkII Escort rack, as an escort rack is mounted in "U" clamps NOT a direct bolt on as in the one linked to in the post above.
A very good point Mark!
I had assumed that as it was a 'Book Chassis' question, with MKII Escort running gear, then answers would be from others with the same.
For the uninitiated, it must be noted that Locost Chassis', ie 'Book Chassis'
are different from the 'Sierra' type (Indy) chassis' and their derivatives.
Fozzie
rj
posted on 2/1/07 at 12:49 PM Reply With Quote
Thanks for all the comments, a question for Bob C, did you manage to identify the thread on the end of the rack, it appears to be a total oddball size , 21mm od x 1.25 or is it .840 x 20 tpi ? but probably academic as i will screwcut on the lathe
posted on 2/1/07 at 12:50 PM Reply With Quote
I have a book chassis and a standard Mk2 rack - I may or may not suffer from bump steer, but it's never bothered me either way. I've driven worse production cars!
It's probably worth trying an unmodified rack first - you may find that there's no problem to fix (or it's not worth fixing).
