Author: Subject: My suspension data. Comments?
Tralfaz
posted on 2/1/07 at 08:23 PM Reply With Quote
Hello All,
Getting ready to fab up my suspension.
Have been modelling it in Susprog3d.
Have managed the Following...
Front:
Roll Center 33mm
RC Lateral Migration >81mm
Camber Gain .54 deg/inch
Rear:
Roll Center 66mm
RC Lateral Migration >40mm
Camber Gain .55 deg/inch
Decent Start?
Regards,
Brian
t.j.
posted on 2/1/07 at 09:59 PM Reply With Quote
Looks good to me
Mine:
RC 45 mm front
RC 90 mm rear
Camber gain front around 0.30 front
Rear not calculated due all the different incl bad design i have seen. Then i became aware most of the building incl. the "fabricant" builds are different and are not following all the principals!
Try to get:
Zero bumpsteer
enough caster at front 5.5-8 degr
RC around 5 front rear around 9 cm
The right ET-value which belongs to the upright your using in front.
And everything will be fine...
Unless you're a formula 1 driver and push the car everyday to the limit.
grtz Theo
[Edited on 2/1/07 by t.j.]
Tralfaz
posted on 2/1/07 at 10:12 PM Reply With Quote
Thanks for your Reply.
Data based on 5 degrees caster.
Have Bump steer down to about 0.1 degrees at the limits of travel
Regards,
Brian
