theconrodkid
| posted on 13/1/07 at 06:28 PM |
diff bolts
i got a rear loader escort diff,what threads are the prop/pinion bolts?
they are not metric fine or coarse,i was told they were unf,not that either or the unf bolts i bought arnt unf?
i tried them against some seat belt bolts and they are different threads.
any ideas?
who cares who wins
pass the pork pies
| posted on 13/1/07 at 07:28 PM |
Oh dear, if you don't have them your in trouble.
Ford don't stock them anymore and nobody else makes them. I think they are unf but you need screws, and there are only bolts available with the
correct thread.
Get yourself down to the scrap yard and take some off a Sierra. QUICK!!
mark chandler
| posted on 13/1/07 at 08:36 PM |
I think in general there are two pitches with UNF, 12 Teeth Per Inch (TPI) and 16 TPI.
Even if you have UNF they still might not be correct, thank goodness we are now nearly all metric when you add in BSF etc .... it becomes a
minefield
[Edited on 13/1/07 by mark chandler]
goodall
| posted on 13/1/07 at 08:40 PM |
or the other thing you could do is buy some bolts of the correct standard new, there must be somewhere local should stock the right spec in metric
goodall
iank
| posted on 13/1/07 at 08:52 PM |
Namrick's table of UNF tpi spanner sized etc is here:
http://www.namrick.co.uk/boltspec.asp
They stock set screws in UNF in high tensile S grades (equivalent to 8.8)
http://www.namrick.co.uk/browse.asp?PCID=5
But without knowing the size/length I don't know if they have what you need.
DIY Si
| posted on 13/1/07 at 08:53 PM |
If you can't find any of the old bolts, just drill and tap some new ones?
Sun Tzu, The Art of War
theconrodkid
| posted on 13/1/07 at 09:00 PM |
burtons do them,they say m10x1......ive tried that already and it wont go in,the 3/8 unf is loose in the threads .
drill and tap is out of the q,its axle out and thats a major job
who cares who wins
pass the pork pies
DIY Si
| posted on 13/1/07 at 09:02 PM |
IS there any one local who is into old fords that may know/ have some lying about?
goodall
| posted on 13/1/07 at 09:09 PM |
drive flange bolts of anything will do im sure, even standard bolts if you not planning on doing any hard driveing
theconrodkid
| posted on 13/1/07 at 09:23 PM |
ive ordered them from burtons,is there such a thing as a finer than 1mm pitch?
anyhow i got my digidash to play with so at least i,m semi-happy
cheers for your replies chaps
[Edited on 13/1/07 by theconrodkid]
who cares who wins
pass the pork pies
procomp
| posted on 13/1/07 at 09:40 PM |
Hi they are deinetly metric and NOT unf.
They are the same thread as the cvh/zetec flywheel bolts.
Many people mistakingly fit unf and f##k up the thread meanig the flange is not safe to use again.
cheers matt
theconrodkid
| posted on 13/1/07 at 09:45 PM |
cheers Mat
who cares who wins
pass the pork pies
bob
| posted on 13/1/07 at 11:52 PM |
John i'll bring the aladins cave box of bolts over tomorow
I have a feeling you may be lucky
Avoneer
| posted on 14/1/07 at 12:20 AM |
The front loader engish is definatley UNF bolts though.
Not that that helps in any way, but I feel better for sharing it.
Thanks,
Pat... (I need some therapy)...
| posted on 14/1/07 at 01:21 PM |
correct thread.
are they different to front loading (english axle) then? ???
for sure they are fine pitch, I would guess UNF.
if you know the dia/pitch, I can try my local fastenere place.
I don't think ou can get a nut on the back sou you would need to tap with anotehr fine as the flange is not the thick.
