theconrodkid
| posted on 26/1/07 at 07:45 AM |
wheels
ok i,m after some wheels for my steed,ive spotted 4 cossie lattice wheels for £80,no tyres.
anyone know the ET/ if they will fit an escort axle on my lego without spacers .
who cares who wins
pass the pork pies
Danozeman
| posted on 26/1/07 at 07:54 AM |
I reckon theyl be 35ish ofset so will probably touch the trailing arms with escort axle. My 38's needed about another inch to go on the hub.
Dan
jos
| posted on 26/1/07 at 09:05 AM |
I had a set of them with 205 50 15's on them. They were fine on the rear but woudlnt rotate on the fronts as they snagged on the wingstays.
I changed them for 13's anyway
Maybe the proper 195 50 15's wouldve solved the probem
theconrodkid
| posted on 26/1/07 at 09:09 AM |
ive been offered some 15X7/et 25,the ones i have at the mo are 14X6 et 16,the 14,s clear the suspension by about 1/2 inch,will the 15,s foul?
who cares who wins
pass the pork pies
PAUL FISHER
| posted on 26/1/07 at 09:35 AM |
fitting a 15x7xet25 in place of a 14x6xet16 you will have 22mm less clearance to your inner strut,and the wheel will also extend out +4mm further out
of your arch,so I would say if you only have 1/2"or 13mm clearance they will foul your strut
theconrodkid
k cheers
who cares who wins
pass the pork pies
PAUL FISHER
| posted on 26/1/07 at 09:42 AM |
If you can get away with a 15mm less clearance to strut,and for the wheel to extend +11mm you could then use standard peugeot fitting 15x7 et 18?
Syd Bridge
| posted on 26/1/07 at 09:59 AM |
C'mon John, you should be putting 19" wheels on that, 15" wide with 345/35 tyres!
theconrodkid
| posted on 26/1/07 at 12:45 PM |
erm...i,m not building a truck syd,its a lightweight fun thang
who cares who wins
pass the pork pies
Chippy
| posted on 26/1/07 at 03:45 PM |
Hi John, I have a set, (5), ford seven spokes with new tyres, (done just 800miles), they are standard ford ET38's, with 195 x 60 x 14 boots. No
flats or kerbing. Complete with a set, (16), of 60 deg loose collar nuts. See my archive for pic's, under wheels. If any good to you, looking
for around £150 the lot. You would need spacers, and longer studs. Regards, Ray
[Edited on 26-1-07 by Chippy]
martthefridgeman
| posted on 26/1/07 at 07:31 PM |
HOW ABOUT USING PEUGEOT RALLYE WHEELS LIKE THESE. 6J/14 AND ABOUT ET18
