John.Taylor
| posted on 31/1/07 at 09:33 AM |
Confused over Goodridge Sierra brakeline kit...
My Goodridge Sierra (non cossie) brakeline kit arrived for my Indy this morning and I'm confused over the fittings on the longer hoses.
The two shorter hoses (presumably for the rear disks) have male ends at each end which is fine as one end will screw into the caliper and the other
end will accept the flared 3/16 solid brakepipe via a female fitting.
The longer hoses (presumably for the front) have a male fitting at one end and a female at the other. I assume that the caliper accepts a male
fitting (but I can't check whilst I get home) and the female fitting goes to a bracket on the chasis. The only problem is, a flare on the solid
brake pipe won't mate up to the female fitting and my flaring tool doesn't have the facility to produce an inverted flare as below.
Is everyone else using flexibles with all male fittings (thus I have the wrong ones) or is there some kind of special fitting that you're all
using that I don't know about?
John.Taylor
| posted on 31/1/07 at 09:43 AM |
When I was last at MK I asked which ones they used and they told me to get standard Sierra ones so I presume that they are correct?
John.Taylor
| posted on 31/1/07 at 10:02 AM |
Sorry about the quality....jpg)
John.Taylor
| posted on 31/1/07 at 10:03 AM |
Another....jpg)
John.Taylor
| posted on 31/1/07 at 10:04 AM |
Another....jpg)
PAUL FISHER
| posted on 31/1/07 at 10:08 AM |
You need,4x part number Goodridge FMV SS-106,these are the kind used in a standard MK kit.
John.Taylor
| posted on 31/1/07 at 10:12 AM |
I thought that they should be male fittings all around. If anyone else has bought Goodridge kits for an MK Indy, can you tell me what the kit
reference on the pack was? The ones I have are SFD0302-4P (Ford Sierra RWD). Which ones do I need?
| posted on 31/1/07 at 10:35 AM |
I think I am correct in saying all those are male fittings (female are like a deep nut) but thee ends are concave/convex. You need to make the
complementary flare on your pipes.
If you pipes are already made up and you are unable to change that, then easiest is to specify exaclty the ends and length (you can trial fit them to
see the length is right) and return them.
John.Taylor
| posted on 31/1/07 at 10:41 AM |
My local motor factors have already said that they will make up the pipes if I mess up the flaring so I guess that I'd better take the Brakeline
kits that I have down for them to have a look at.
And I thought that the brakes would be the easiest bit!
John.Taylor
| posted on 31/1/07 at 10:45 AM |
Paul, I think that FMV SS-106 is the Department of Transport (DOT) regulation that the Goodridge Brakeline kits conform to rather than the Model
Number.
Still interested in the correct model number if anyone has it as swapping them seems the easiest option.
PAUL FISHER
| posted on 31/1/07 at 11:52 AM |
Number.
Yes your right John,its just Ive got a set in a box in my garage,that Ive never used,as I needed different ones for the brakes Ive fitted,so I just
posted what I thought was the part number
mark chandler
| posted on 31/1/07 at 05:16 PM |
Just out of interest how much do these cost ?
I only ask as I got a Goodrich brakehose kit for a Landrover "90" which is ideal and costs around £25, set of three hoses metric.
Regards Mark
robinj66
| posted on 31/1/07 at 06:18 PM |
Have a look here - no idea if the price is OTT or not
http://cgi.ebay.co.uk/Goodridge-Brake-line-Kit-Ford-Sierra-RWD-Not-Cosworth_W0QQitemZ8073423441QQihZ019QQcategoryZ23013QQtcZphotoQQcmdZViewItem
NTDWM
