Author: Subject: Polybush fitment
bodger
posted on 11/2/07 at 03:03 PM Reply With Quote
Polybush fitment
Fitted a top wishbone arm last night & it was so tight it could hold up the whole wheel up on its own! and that was after filing the tube seam out & removing any powder coating left inside the tube. Despite being reassured that the crush tube should be a tight fit I think its way too tight.
Just found this info on the net about fitting poly bushes which seems to make a lot of sense so it looks like I'll have to tweak the bushes on a lathe.
What I can't understand is why nobody else has had this problem.
Where is a good source for stainless crush tubes ?
MkIndy7
posted on 11/2/07 at 03:20 PM Reply With Quote
Possibly a silly question but did you use any grease when assembeling them?.
I didn't think they needed them until about 2 months after the car was on the road and it delevoped a terrible squeeking noise lol
Amazing the difference a bit of grease makes!
posted on 11/2/07 at 03:41 PM Reply With Quote
I just tickled the end edges of the bushes to allow easy insertion then gave them a good slap of copper slip. Quite stiff initially but sweet now.....
mark chandler
posted on 11/2/07 at 04:08 PM Reply With Quote
My experience of polybushes, on landrovers, is that once you have pushed in the bush the steel insert onced greased up can be pushed in by hand.
The bush will rotate on the insert/crush tube but once you have taken up the free space either side of the bush it will take a lot of force to twist/lateral move.
Either way you should not be able to pick up the car, maybe the wishbone tube is a little small so you now have to compensate on the crush tube.
Regards Mark
bodger
posted on 11/2/07 at 05:26 PM Reply With Quote
Yes, I lubed them up with plenty of moly grease but it still took a lot of force in the vice to push them in. I'm sure they will free up a bit when on the road but I still think they're way too tight a fit to work properly.
flak monkey
posted on 11/2/07 at 05:31 PM Reply With Quote
Mine were the same. Inner tubes very tight in the poly bush itself. Seems to work fine though...! And they dont take that much force to move once the bones are bolted up to the chassis. Though they will support their own weight quite easily.
Sera
http://www.motosera.com
Dave Bailey
posted on 11/2/07 at 10:31 PM Reply With Quote
I fitted my bushes recently to my Velocity and they needed to be pt in with a nylon mallet. The thing is that the steel tubes actually are shorter than the bushes and so the wishbone will not move on the tube. Is this normal? The assy instructions state tighten up then slacken the nut until the bolt starts to turn.......
flak monkey
posted on 12/2/07 at 07:30 AM Reply With Quote
Not this again...
The crush tube should be held firmly between the bracket by the bolt, which means do the bolt up FT...
Any other way the bush really isnt doing its job. Search for previous posts on polybushes, plenty of detail.
Sera
posted on 12/2/07 at 08:46 AM Reply With Quote
If the bushes/ crush tube are too tight when the bolt is tightened so that the arm will not move IMO there will be to much strain on the arm and the brackets. Stripped all my arms off after being on the road for a year , removed all weld burrs etc from inside arms retried and still found them too tight. On measuring the crush tubes were found to be too short . Ended up skimming the top hat section of the bush . Reassembled with rubber grease and tested each arm by nipping in vice an rotating arm around crush tube. Ride and handling are now very much improved without jarring my spine everytime car hit a bump. Suspect some suspension arm failures may ?? be due to overtight bushes/crush tubes
bodger
posted on 12/2/07 at 12:53 PM Reply With Quote
Quote from Fisher Fury build manual:
'Fit the rocker arm first, this pivots on an M12 x 225 bolt, using tube ferrule and nylon tophat section
bushes. These bushes will be a tight fit in the rocker arms, the tube ferrule must be 0.5mm longer
than the bushed arm and must be able to move freely.
If the ferrule is too tight in the nylon, ream out
with an old bolt slotted and fitted onto a drill with emery cloth. Some resistance is acceptable – too
loose and you will have slack suspension!'
Considering the difference it will make to the handling it sounds like it's worth spending a bit of time getting this bit right.
procomp
posted on 12/2/07 at 01:59 PM Reply With Quote
Hi what has been qoueted from the fisher build manuel above is the correct way of doing the job.
Any other way means that the suspension is going to suffer from stiction bad enough to cause problems on the car when driving .
Whether you are able to realize you have and be able to notice these problems when driving is another question alltogether.
cheers matt
Dave Bailey
posted on 12/2/07 at 07:12 PM Reply With Quote
I take the point.....I don't know how many Luego people have built their suspensions in the way that he manual states. My crash tubes are shorter than the bushes...... Looks like I will be taking it all apart again. What doesn't make sense is that the front suspension has some spacing washers fitted which means that the crash tubes will not move in the bushes but the arms will move on the bolt. Have a read of the Luego manual on the web site.
strange
Dave B.
posted on 12/2/07 at 07:14 PM Reply With Quote
There wasn't a manual when I built my suspension and yes the crush tubes are too short. Thats why I skimmed the top hat section
Dave Bailey
posted on 12/2/07 at 07:36 PM Reply With Quote
Just sent Dean @ Luego a note to get some more bushes..... Did you say you left the crash tubes protruding by 0.5 mm?
thanks
Dave B
posted on 12/2/07 at 09:55 PM Reply With Quote
Probably more like 0.25mm , Dean was told about problem at Newark last year .
