Author: Subject: brake pipes
welshboy
posted on 11/2/07 at 07:13 PM Reply With Quote
brake pipes
hi all is nickel pipe much better than copper pipe
Dave Bailey
posted on 11/2/07 at 07:18 PM Reply With Quote
...... Kunifer is the one to go for......
RichardK
posted on 11/2/07 at 08:06 PM Reply With Quote
Is this the gear?
Linky
Rich
Gallery updated 11/01/2011
posted on 11/2/07 at 09:10 PM Reply With Quote
Thats the one but check with your local motor factors first
daviep
posted on 11/2/07 at 10:06 PM Reply With Quote
What exactly are the benefits of kunifer over copper?
jollygreengiant
posted on 12/2/07 at 03:40 AM Reply With Quote
When you need to undo a pipe, it will come undone with twisting the pipe because the nut hasn't permanently joined itself to the copper brake pipe.
Also kunifer does not go a funny colour.
Kunifer is technicaly a stronger pipe for the same wall thickness.
posted on 12/2/07 at 07:33 AM Reply With Quote
Kunifer has better fatigue ressistance.
posted on 12/2/07 at 08:48 AM Reply With Quote
Hope you mean without twisting the pipe Clive? although brass nuts should be used with copper pipe to get the same result.
Bluemoon
posted on 12/2/07 at 09:46 AM Reply With Quote
The only problem with kunifer pipe is finding a pipe flaring tool designed for it as it's harder than copper...
Dan
posted on 12/2/07 at 10:24 AM Reply With Quote
is it worth spending the extra on the kunifer pipe and the tool?
We all hear about its advantages over copper but I have not heard of anyone having any trouble with plain copper pipes; they should be marked with some approval stamp so are fit for the puprose and SVA men seem happy with them.
posted on 12/2/07 at 10:54 AM Reply With Quote
I have a cheapo brake flaring tool from Clarke and it flares Kunifer with no problems. I get pipe from the local spares shop where it costs about the same as copper and it's a lot less than he's asking on ebay.
posted on 12/2/07 at 11:11 AM Reply With Quote
You are correct in saying that copper pipe is used by many people, and problems are rare. However, its use is forbidden in many countries (e.g. the USA) as they believe that it is prone to failure due to work-hardening and fatigue - I believe that they only allow steel (which seems daft, as that rusts). You would have to make your own decision (but it's worth noting Volvo always used to prefer kunifer pipe).
As kunifer is only a couple of Pounds more expensive, why not use the good stuff anyway, and be sure?
[Edited on 12/2/07 by David Jenkins]
posted on 12/2/07 at 11:29 AM Reply With Quote
Dan
The problem of slipping through the die occurs with all types of pipe and all makes of tool, really just a matter of taking a tiny thickness of material off the flat mating surfaces of the die so they clamp the pipe properly.
It is worse on the tools sold by Clark and Machine Mart because the surfaces are plated, just rub the dies down on wet and dry paper on a flat surface, or if you are a true perfectionist some fine grind paste on a bit of plate glass.
