Ivan
| posted on 13/2/07 at 10:09 AM |
Well pleased with my pedals
Finally finished the pedals . Well pleased with them  - had them waterjet cut from Aluminium - interestingly enough it was cheaper than cutting
from steel.
It looks like I'll have room for a footrest as well
Now to make the fitting brackets for them
[Edited on 13/2/07 by Ivan]
macnab
| posted on 13/2/07 at 10:27 AM |
yip their cool
| posted on 13/2/07 at 10:50 AM |
nice, but isn;lt here one missing?
what alloy are they made from? you TIG them yourself?
you can have a go at the DIY anodising to make them even more flashy
| posted on 13/2/07 at 10:54 AM |
Yup- I looked into DIY anodising a while back. Pretty simple really. Helps to get the dyes hot, you need to have a pot big enough to hold the
workpiece without it touching the sides. Of course I wanted to anodise the parts black which is one of the hardest colours to pull off (you tend to
get a grey colour unless you use horendously expensive (but strong) dyes)....
I went and bought all the bits then never did it....
Ivan
| posted on 13/2/07 at 11:29 AM |
Yep - still have to decide on Accelerator design - need 45mm pull on cable - will look for suitable in scrapyard then modify to suit.
Have never heard of DIY Anodising - will do search for info and maybe try it - thanks for the idea.
The Al is 5083 - a mate tigged it for me as I don't have tig.
Am also busy making Al seats - will post pic when finished.
Lastly - thanks for the positive feedback
3GEComponents
| posted on 13/2/07 at 12:58 PM |
Have a look here
http://astro.neutral.org/anodise.shtml
http://www.focuser.com/atm/anodize/anodize.html
