heyzee
| posted on 4/7/03 at 03:48 PM |
front wishbones
does anyone have any plans for a bottom set of wishbones useing maxi balljoints.and a better way rather than prat around squashing tubes.can a plate
not just be welded on top of the tubes
Mark Allanson
| posted on 4/7/03 at 07:51 PM |
Squashing tubes isn't so bad, if you use Maxi lower joints you will have to use a bender to shape the tubes to the correct radius, and this may
compromise the steering lock and strength.
I made mine fairly book, but with out the little window bits either side of the balljoint plates. They took a little time to get right but I am
pleased with them.
