Macca
| posted on 4/7/03 at 07:46 PM |
Wishbone id
Could you please spare a little time to look at the photo's in my archive as I would like to try and id the supplier of these wishbones.
They are a little wider between their mounting points, and the tube that holds the mounting bushes is a little shorter than book.Most other
measurements would appear to match the book.
They came attached to the chassis, pictured, which I would also like to id,
this has not been a home build.
Thanks for your comments.
Col
craig1410
| posted on 4/7/03 at 08:58 PM |
Macca,
It looks like MK Engineering handywork to me. Your de-dion setup is MK's the same as mine and I think the wishbones look like the ones which MK
used to show on their website (the non Indy ones designed for book chassis'
I'm not certain but the whole bent pipe wishbone design (I think) was started by them. (Waits to be corrected...)
HTH,
Craig.
kingr
| posted on 4/7/03 at 11:46 PM |
Yup, certainly look like MK bits to me, although presumably they're quite old given a) their condition and b) that the top wishbone
doesn't appear to have an angled threaded section for the ball joint (or in this case spherical bearing). Watch out though, you might have the
MK dimension protection cult after you if those pictures with the ruler fall into the wrong hands. The welding quality is another giveaway.
Kingr
[Edited on 4/7/03 by kingr]
