Shaw
| posted on 13/2/07 at 08:59 PM |
Bike Coilovers
Does anyone out there know if you can use bike coilovers as opposed to proper car ones?
I did see a post with some on but not sure how well they would work.
would you have to offset the linkage to get the same bending moment?
| posted on 13/2/07 at 09:14 PM |
several people have used them. Main problem is that the spring rate is much higher (leverage on the bikes swing arm) and travel is quite low, so you
need to ratio them, either with a rocker or a push/pull rod. I believe sgraber used them, so there should be details on his website.
I had a collection of r1 and r6 shockers which i sold recently, i still have one left if you want one to model.
Marcus
| posted on 14/2/07 at 06:38 PM |
For our first car, we used bike shocks with car springs. They lasted a year and dumped their oil all over Stoneleigh!
Replaced with Gaz - no more problems. They were the most expensive parts of the car at £250, but money well spent IMO.
Marcus
Because kits are for girls!!
| posted on 14/2/07 at 06:51 PM |
With car springs, id expect the shocker to move a lot more (edit, more than the available travel), and probably be over damped. The rear wheel of a
bike probably sees 150kgs with a fatty riding it, so that would make them ideal for a 600kgs car. Just the leverage issue then.
Here's steves car, the pull rods are visible at the front:
  La Bala rolling chassis May 1, 2003
[Edited on 14/2/07 by JoelP]
andyps
| posted on 14/2/07 at 07:05 PM |
Joel - what do you have left? I am after one to see if it might suit my front end design.
xico_ze54
| posted on 14/2/07 at 08:30 PM |
Marcus,
what is the right reference of Gaz shocks for Locosts?
where did you buy them?
thks
Amadeu
Shaw
| posted on 14/2/07 at 08:33 PM |
I like the idea of a push rod will have to start reading up for the calc's. the coilover you have left over is it a piggy back type?
How much would you want for it?
| posted on 14/2/07 at 09:46 PM |
http://cgi.ebay.co.uk/Yamaha-R1-5PY-Rear-Shock_W0QQitemZ180084370895QQihZ008QQcategoryZ10490QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.co.uk/yamaha-R1-shock_W0QQitemZ130078399503QQihZ003QQcategoryZ10490QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
its like the second of these. They're not rare though, a month of browsing ebay would yield a set fo £75. Dont assume they are any lighter than
car shocks, the only benefits i can think of is cheap, adjustable (maybe 2 way adjustable, im not sure) plus you can run them horizontal. Also with a
few holes in your rocker pivot you can change the ratio quickly.
Ive just sold it actually, but they arent hard to find.
key words are r1/r6/shock/shocker
