Author: Subject: Master cylinder sizes
Mix
posted on 6/7/03 at 03:45 PM Reply With Quote
I originally added this question to a thread in SVA & Legal but realise it's more in context here.
I intend to use a dual master cylinder system with a balance bar, is there a way of determining what bore cylinders to use?
I will be using Cortina callipers on the front and Sierra XR4x4 rear callipers. I presume it will boil down to piston areas, pedal ratio and vehicle weight.
Thanks Mick
eddymcclements
posted on 7/7/03 at 08:30 AM Reply With Quote
I'm using Cortina front (M16) and XR4x4-type rear calipers. The pedal box and bias bar came from Stuart Taylor and I bought the master cylinders from Rally Design. The sizes recommended by ST are:-
front 0.625
rear 0.75
Hope this helps,
Eddy
Findlay234
posted on 7/7/03 at 09:06 AM Reply With Quote
How did you pass SVA with the master cyls from raldes? What did you do about low level monitoring?
kiwirex
posted on 8/7/03 at 08:31 AM Reply With Quote
Carroll Smith talked about this in "tune to win"
(and they're an excellent set of books).
It's about the ratio of the diameter of the master to the diameter of the slave. Small master + large slave == lots of pressure on brakes for little foot pressure, but lots of travel on pedal too.
Similar effects can be had by moving the <technical term> bit where the master cylinder (s) join on to the pedal </technical term> closer or further from the pedal pivot.
ummm... Not making much sense here am I - see if you can get the book from the library.
Greg H
Dick Axtell
posted on 8/7/03 at 08:33 AM Reply With Quote
Mcyl Bore determination
Guys,
For a full analysis of a vehicle brake system, and to assess the compatibility of the various components, you'll need a whole clutch of info. See the attached jpg file, which illustrates what's needed.
