Author: Subject: Shock mounting bracket width
ecosse
posted on 21/2/07 at 12:24 PM Reply With Quote
As per subject, I don't have my shocks yet, but want to get the brackets mounted to the chassis for them (not standard "U" type mounts).
So, how wide do I make the brackets, i.e. is 20mm enough for your average GAZ, AVO, spax etc, shock mounting?
I would hate to weld these in place to find out they are too tight for the shocks
but I don't want to have to use loads of spacers to install them either.
So if anyone could measure theirs for me that would be great
Alex
posted on 21/2/07 at 12:38 PM Reply With Quote
Across the bush my Gaz is 35mm so 20mm will not be enough.
ecosse
posted on 21/2/07 at 01:10 PM Reply With Quote
35mm glad i asked now, i'll aim at 40mm to be safe then.
Alex
3GEComponents
posted on 21/2/07 at 01:11 PM Reply With Quote
Alex,
AVO specify 1 1/4" (31.75mm) for poly bushes and 16mm for sperical bearings.
John
ecosse
posted on 21/2/07 at 02:12 PM Reply With Quote
Cheers John,
I reckon I'll make them 40mm and then just make spacers to suit whatever shocks I end up buying
Alex
