goodall
| posted on 2/3/07 at 10:46 PM |
mating bolt on CV's to a UJ output flange?
can you do this? without going to the machine shop?
Liam
| posted on 3/3/07 at 01:22 PM |
Well you could weld the uj yoke to the cv flange, but it'd have to be done very well with perfect concentricity. Wouldn't do that
myself.
So unless they just bolt up, obviously you'll need to do some machining. The minimum would be to drill the cv flange to take the uj yoke if
that's possible. Otherwise you'll need to make an adaptor that fits between the cv flange and the uj yoke.
Liam
goodall
| posted on 3/3/07 at 02:31 PM |
no its the other way round to that, its a bolt on cv joint to a uj output flange
| posted on 3/3/07 at 04:03 PM |
If you are lucky the flange might be able to be re-drilled if it's diameter is large enough, otherwise you are looking at making an adapter to
sit between the two. As said, you can't afford anything rough and ready here, the two must be concentric or you will suffer from vibration and
possibly premature failure of the diff/bearings/CV. Unless you have access to a lathe I think this would need the machine shop.
goodall
| posted on 3/3/07 at 07:19 PM |
well i've done some looking at the whole thing today day and have decided to make somthing like this
goodall
| posted on 3/3/07 at 07:21 PM |
and
goodall
| posted on 3/3/07 at 07:22 PM |
should work perfectly i think as long as i get every thing dead on centre.
