Kosmo
| posted on 3/3/07 at 08:57 PM |
Sierra LSD Diff Oil ?
I'm about to clean up my diff and install new seals and get it all ready before my chassis arrives .... I was thinking of changing the diff oil,
is this recomended and if so what type should I use or should I leave it alone ?
The diff is a 7" 4x4 lsd type (3:62)
Kosmo.
miegru
| posted on 3/3/07 at 09:17 PM |
When I filled mine I talked to BGH gearboxes and they reccomended to use the standard ford oil.
graememk
| posted on 3/3/07 at 09:18 PM |
the lsd is sealed so use normal oil.
Kosmo
| posted on 3/3/07 at 09:53 PM |
What do you mean normal oil....?
Kosmo.
the_fbi
| posted on 3/3/07 at 10:52 PM |
Kosmo.
Normal diff oil.
Chippy
| posted on 3/3/07 at 11:53 PM |
It is "I think" EP 90, if not its EP 80. Think either would do, and as the diff is probably worn a bit I would go for the EP90. HTH Ray
blueshift
| posted on 4/3/07 at 11:15 AM |
I have the haynes manual, it specifies one kind of oil for both open and LSD:
"Hypoid gear oil, viscosity SAE 90 to API GL5 (Duckhams Hypoid 90S)"
Kosmo
| posted on 4/3/07 at 06:01 PM |
Cheers guys... thats the info I need
Dave Bailey
| posted on 4/3/07 at 09:44 PM |
Ford still sell it and it's not expensive! Can't remember what it was though!
blakep82
| posted on 5/3/07 at 09:14 PM |
I've got a BMW with LSD, and i wouldn't put standard diff oil in it... always LSD oil. usually about £10 per litre. you can get it from
rally design easy enough
the_fbi
| posted on 5/3/07 at 09:18 PM |
But your BMW has a totally different type of LSD so it needs LSD oil
The Sierra diffs are sealed and contain their own LSD oil which isn't replaced/changed. Just normal diff oil needed for the CWP.
