the moa 2
| posted on 4/3/07 at 10:49 AM |
Blank Steering Wheel Fitment
Can anyone help me im trying to make a good job of fitting my undrilled steering wheel.
It has a centre pre marked and i need to fit it to my three hole quick release boss.
I could roughly guess and try and scribble a mark in the holes but im sure that someone with a bit of brains can tell me how to precisely mark the
holes.
nitram38
| posted on 4/3/07 at 11:58 AM |
Lay a piece of paper over the boss and trace the holes. Cut this out and place over your steering wheel. Centre punch the holes and drill.
daviep
| posted on 4/3/07 at 12:49 PM |
If you want to do it in a slightly more scientific manner.
1: Accurately measure the distance between any two bolt holes (centre to centre) in the hub, call this measurement (x)
2: Insert measurement (x) into this equation to get the bolt hole PCD:
3: Once you have the PCD use a pair of dividers or a compas and pencil to draw it on to the steering wheel (remember set dividers to half PCD)
4: Again using dividers set to original measurement of bolt hole centres mark these on the PCD line.
Good idea to try it on paper first .
Regards Davie
P.S. If anybody wants to try this let me know if it works
the moa 2
| posted on 4/3/07 at 02:45 PM |
AH-HA this is what im after will try and let you know.
Many thanks
nitram38
| posted on 4/3/07 at 02:55 PM |
Well I did it the tried and trusted method and both wheels I did are perfectly true
