Pdlewis
| posted on 9/3/07 at 10:56 AM |
Steering column support
I have just had to put a UJ in my steering column to overcome a clearence problem caused by the robin hood manifold the proble i now have is the
column now needs supporting otherwise it falls into either the chassie or engine
i have a chassie rail running next to the column so was thinking of putting it through a rose joint which would be attached to the chassie. is this
ok or does anyone have an easier suggestion?
Paul
Mr Whippy
| posted on 9/3/07 at 11:01 AM |
that is the method I am using, the only trouble I'm finding is getting a rosejoint with a 15mm bore as the metric ones go from 14mm - 16mm!
Agriv8
| posted on 9/3/07 at 11:02 AM |
that is how I have done it but using sperical bearing here's a photo
  steering UJ
regards
Agriv8
Pdlewis
| posted on 9/3/07 at 11:05 AM |
That looks like what im trying to achive. couple of questions:
1. How have you fixed it to the chassie?
2. where do you get the bearings from?
cheers
Paul
Agriv8
| posted on 9/3/07 at 11:21 AM |
cheers
Paul
A1 the bracket Cups arround the chassis rail and bolted all the way through ( stop it moving ) the bolts you can see popping though the side
pannel
A2 the bearing and beaing housing were from marc at mnr. used for their bottom front wisbone arm.
if you want a better photo let me know
caber
| posted on 9/3/07 at 03:24 PM |
I had the same problem and made my own split bearings as I had to pick up on sections of the shaft with either a joint or splines on.
Caber
Pdlewis
| posted on 9/3/07 at 03:29 PM |
hi Agriv8
Would you be able to stick a couple more photos up? it looks like this solution would work very well with my problem
Paul
snapper
| posted on 9/3/07 at 06:29 PM |
Solution from Gavinc on the Rhocar site
RHOCAR thread
I eat to survive
I drink to forget
Agriv8
| posted on 13/3/07 at 09:08 AM |
Sorry for the delay cant access locostbuilders form home
here are some picks as promised.
  steeer1
  steer2
regards
Agriv8
