8smokingbarrels
| posted on 18/7/03 at 08:15 PM |
Do I need a driveshaft?
Im thinking of using Fiesta uprights which of course are FWD
As my car will be RWD- the front driveshafts are redundant- but are they? What I mean is- will the hub have too much freeplay because it is no longer
torqued up to the driveshaft (by the driveshaft nut)
Looking at the upright (essentially the lower part of the fiesta strut) the bearing seems to have little room for lateral movement so Im not sure if
being torqued up to the driveshaft will make much difference. Hope someone can advise!
chris
theconrodkid
| posted on 18/7/03 at 08:25 PM |
you can pop the cv joint off the drive shaft,just use the joint or the bearing will go awol in a few yards
who cares who wins
pass the pork pies
8smokingbarrels
| posted on 20/7/03 at 10:03 PM |
Thx for the reply Conrod
I will take ur advice on this- to be honest its in line with what I thinking of doing. Less chance of the bearing moving about if its securely
attached to the end of the driveshaft.
The guy at the scrapyard nearly had to resort to a sledgehammer to shift the mondeo upright off its shaft! Not to mention the trouble I had getting
the brake disc off - thank god for angle grinders!
