Author: Subject: Sanity check - thread engagement on Wheel studs.
bigandy
posted on 24/3/07 at 04:46 PM Reply With Quote
Afternoon folks.
I'm just about to lower my car off the build trestles for the first time, and I am suffering from a bout of "doubtingmyself-itis". Can someone just confirm Mr SVA man is okay with the following:
I have Sierra ally wheels on my car. They are fitted using the correct taper (60° IIRC) wheel nuts that are open. The studs and nuts are M12x1.5mm. The nut engages approximately 10 turns on the stud, but the stud end is approximately 7mm short of the outside face of the nut. The nuts are 25mm long in total, meaning there is a thread engagement of at least 15mm (possibly 17mm). My instinct tells me this should be okay, but as above, I am doubting myself now...
So, is this okay for Mr SVA man? and if it is not, what is the easiest way to change studs on a sierra hub (the press in ones) without dismantling the suspension and brake calipers etc etc..
Dammit! Too many decisions....
wilkingj
posted on 24/3/07 at 05:57 PM Reply With Quote
I had a similar issue when I fitted my wheels (team Dynamics)
However, for £16 I fitted longer studs all round.
Better safe than sorry IMHO.
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 24/3/07 at 06:33 PM Reply With Quote
10 turns is safe (edit IMHO!) if torqued up to the correct setting, however im not sure if its enough for the law. I think i read you need 1.5 times the stud diameter engaged, but a spot of research would confirm this either way.
[Edited on 24/3/07 by JoelP]
flak monkey
posted on 24/3/07 at 06:37 PM Reply With Quote
1.5x thread diameter is the general rule yes
Sera
http://www.motosera.com
wicket
posted on 24/3/07 at 06:39 PM Reply With Quote
See here
http://www.needforspeed.co.uk/htmlpages/TechWheels.htm
posted on 24/3/07 at 09:05 PM Reply With Quote
Have a read of this thread.
They're cheap and easy enough to change and not worth a fail at SVA. Just go for the longest studs and cut the excess off.
Phil
bigandy
posted on 24/3/07 at 09:50 PM Reply With Quote
Thanks for the links/tips folks.
I had a thought though, the Hubs are Sierra, the wheels are off the same Sierra. I did replace the studs in the hubs, with ones that are exactly the same length as the originals. The only thing that has changed is the wheel nuts.
I don't recall how many turns the original nuts were engaging on the stud, but it cannot have been more than 9-10...
As for the thread engagement, then I have at least 15mm at the moment, which is 1.25x thread diameter, which should be enough.
I think I'll see what mr SVA man has to say, and when I come to invest in some fancy wheels post SVA time, I'll reassess the studs then.
Chippy
posted on 24/3/07 at 10:29 PM Reply With Quote
When I went for SVA my car was fitted with the sierra wheels, ( from the doner vehicle), wheel nuts went on more or less exactly ten and a half turns. This was checked at SVA and found to be acceptable, and that was at Southampton, who are very strict on the reg's. HTH Ray
