heyzee
| posted on 26/7/03 at 04:21 PM |
shockers
i have a set of zeemering shocks(or however you prunounce it)to fit to my build they are the right length but the metalastic bush on eather end is
only about an inch wide,do you pack the brackets with washers or make the brackets to suit.has anyone had the same problem? also when offering the
shocker up to where it is to be mounted it looks like it may catch the chassis with the cup part that compresses the spring has anyone any ideas or
measurements
| posted on 26/7/03 at 07:23 PM |
I made brackets to fit the shocks and mounted them on the side of the top rail. They clear the rail and fit through the top wishbone alright.
yours, Pete.
heyzee
| posted on 26/7/03 at 08:30 PM |
shocks
pete im sorry i mean the back end i should have said
steve m
| posted on 26/7/03 at 09:01 PM |
Mine are all packed out with 8mm washers
not sure if its correct but it works
heyzee
| posted on 26/7/03 at 09:17 PM |
shocks
did you have any trouble at the back end with the shocker catching on the frame
| posted on 27/7/03 at 09:16 AM |
I used two short pieces of tube.
I put them either side of the eyes on each end of the shocks. I think the bolts I used were 3/8". I welded the brackets on after I got the
shocks in place so they cleared everything.
yours, Pete.
