Author: Subject: Very Early BEC Spotted
Guinness
posted on 23/4/07 at 12:50 PM Reply With Quote
At Cadwell this weekend.
Early BEC
Early BEC
Was a twin of some description with an external clutch, chain drive to a gearbox, then chain to diff. Transverse leaf springs at the front and back. Notice how you can move the hubs and the leaf spring up and down the upright!
Also notice the rillly small driver!
Front suspension was a mirror image, just with steering rack instead of the prop shafts!
Mike
zxrlocost
posted on 23/4/07 at 12:53 PM Reply With Quote
what was that performing like?
Mr Whippy
posted on 23/4/07 at 01:25 PM Reply With Quote
Quite a cleaver suspension system, minimalist in the extreme. That tiny driver also seams to be fitting the wrong way round silly little Oompa Loompa
mark chandler
posted on 23/4/07 at 05:16 PM Reply With Quote
I saw something similar in the 80's at a hill climb. It had a vincent motor and even then was years old.
Not very fast but good fun !
Regards Mark
12a RX-7
posted on 23/4/07 at 05:21 PM Reply With Quote
looks a little like corvette rear suspension only they are using the leaf spring as an upper wishbone and the vettes is isolated with a drop link and uses a multi link setuo ... would be interesting to know how the spring handles the axial loads does is distort into an S shape ?
posted on 23/4/07 at 06:16 PM Reply With Quote
would be a lot of bending on the spring under accleration, and your antiroll is totally linked to your spring rates! Interesting though.
Guinness
posted on 23/4/07 at 07:32 PM Reply With Quote
Interestings not the word with cable operated drum brakes on the front!
Didn't see it run unfortunatley.
Mike
