robertst
posted on 14/5/07 at 02:27 PM |
Can i do this?
would this be ok as steering linkage?
cheers .
column bush
[img][/img]
Tom
theconrodkid
posted on 14/5/07 at 02:29 PM |
you will need a support just above the lower UJ, or it will flop all over the place,i used a rose joint
who cares who wins
pass the pork pies
dan__wright
would think it will need a support on the middle section,
why are you doing it like that? clearance?
ps your steering wheels on the wrong side
robertst
posted on 14/5/07 at 02:34 PM |
very funny...
anyway, i made it out of the parts i currently have and it seems good enough or probably a better choice rather than weld both ends together.
i was also thinking about what the SVA manual says about the upper and lower sections being offset in case of collision.. and this looks ok... so a
rosejoint huh? can i just make a bracket out of steel sheet, drill a hole in it, weld it and pass the tube through it?
many thanks!
Tom
theconrodkid
posted on 14/5/07 at 02:37 PM |
ive been there.....believe me you need a smooooooooth action on the column,easiest way i found was column through the rosejoint eye,and as dan
says,its on the wrong side
who cares who wins
pass the pork pies
robertst
posted on 14/5/07 at 02:57 PM |
many thanks, you wouldnt happen to have a pic of this would you? i dont really know where to put it.
Tom
Mr G
posted on 14/5/07 at 03:08 PM |
Example
The Tiger Avon has the same arrangement as you and uses a Rose joint to support the lower section of the column, immediately below the lower UJ. The
Rose joint is mounted on a chassis bracket.
A post in the Tiger section should get you some pics to look at.
^^^^^^ like that^^^^^
[Edited on 14/5/07 by nick205]
robertst
posted on 14/5/07 at 03:11 PM |
thanks a lot! i just found those pics in another thread...
ordered the bearing from Raldes... one problem solved...
Tom
tks
posted on 14/5/07 at 03:32 PM |
maybe its not nececarry,
but you don't use the rubber grommet thing now.
Tks
Avoneer
posted on 14/5/07 at 03:40 PM |
No no no no no no...
That top joiners clamp will never hold it in a crash.
Pat...
posted on 14/5/07 at 04:22 PM |
Pat...
It looks like it's floating in mid-air...
robertst
posted on 14/5/07 at 06:14 PM |
Pat...
err? thats because it is... i'm gonna put a support somewhere in the middle..
pat wot do u mean? thats from the sierra! if it works in a sierra it might as well work here!... or do you mean the middle one?
Tom
Avoneer
posted on 14/5/07 at 10:19 PM |
It was a joke about the one at the top.
All looks good to me - just needs a spherical bearing between the bottom two UJ's - just like the Avon.
Pat...
robertst
posted on 14/5/07 at 10:59 PM |
Pat...
YE HAVE A FUNNY SENSE OF HUMOUR DON'T YE?!!
Tom
