RazMan
| posted on 24/5/07 at 10:18 PM |
Notchy Steering
My adjustable column has got a plastic support bearing which often starts to bind so the action gets very tight.
I want to replace it with a proper ball bearing but I need something really low profile as anything big will get in the way of my brake pedal.
I think someone posted a pic of a split pillow bearing that might do the job. Can anyone point me in the right direction for finding one? Failing
that, any other ideas for supporting the column firmly?
Raz
Dusty
| posted on 25/5/07 at 12:24 AM |
This one on the North West Hoodies site may be useful. Details a bearing which works
well.Steering support bearing
| posted on 25/5/07 at 07:29 AM |
RS components sell bearings (I have account if you need to buy one).
DaveFJ
| posted on 25/5/07 at 08:02 AM |
I got my new engine mounting rubber from these people link. they sent me 2 thick catalogues full of different
bearings and all sorts..... reasonable prices (for some of their kit) and really good service. thye didn't turn up their nose at my £7 order
either
Dave
big_wasa
| posted on 25/5/07 at 09:21 AM |
Reading about the bearing used in the hood. The part number is wrong. It should be " SLFL25 "
Rs do them for about £12.55 They also do a 3 bolt version " SLFE25 " forthe same money.
Link
RazMan
| posted on 25/5/07 at 01:23 PM |
On closer inspection the cause is now clear
Raz
RazMan
| posted on 25/5/07 at 01:28 PM |
The bearing fell out in four pieces!
Replacing this with a needle roller isn't ideal. The od & id is 34mm & 28mm and tbh I would like to move the bearing away from the brake
pedal a little more.
The triangle section lower down in the column normally has a bearing fixed doesn't it? ... or am I thinking of another column?
[Edited on 25-5-07 by RazMan]
Raz
iank
| posted on 25/5/07 at 02:02 PM |
Can you get a phosphor bronze bush that size? It wouldn't smash up like the plastic bush.
Anonymous
| posted on 25/5/07 at 03:31 PM |
On the Sierra column the lower bearing is a fairly cheap and nasty three piece plastic bush. You can buy them for a few quid at motor factors or ebay
etc.
I'd have thought a needle roller was the only choice if you want a bearing with simmilar dimensions to the original bush?
EDIT:
Actualy, you might be able to use a spherical bearing to solve the problem and eliminate the door hinge solution: e.g.
http://www.ondrives.com/products.asp?recnumber=872
[Edited on 25/5/07 by MikeRJ]
NS Dev
| posted on 25/5/07 at 05:00 PM |
phosphor bronze
RazMan
| posted on 25/5/07 at 05:03 PM |
etc.
EDIT:
As I said earlier, I really want to move the bearing further down the column as it gets in the way of my foot when pressing the brake pedal (bit scary
sometimes) so the triangle nasty bearing might be worth looking at ..... although those spherical bearings look rather tasty don't they.
Either way I would imagine I will have to grind off the flange at the bottom of the column tube to allow a bearing of any sort to be slid on.
btw I got rid of the door hinge in the end - too much slack which made the steering inprecise.
Raz
saigonij
| posted on 26/5/07 at 12:41 PM |
I just ordered my bearing from link above.
Guy knew exactly which website i was talking about !!! must have alot ordered!
i love this site, so many cool tips!
JB
| posted on 26/5/07 at 03:34 PM |
Column Bearing
On my Kitten I used a real nice column bearing from a Fiat. It had a ribbed rubber outer and needle roller inner. The OD was about 10mm larger than
the ID.
The rubber allowed a little flex to take up any out of true. The needles gave low friction running.
These are the best pictures I have. The bearing is at the top of the column.
NS Dev
| posted on 28/5/07 at 10:16 AM |
I have one of those columns if you want one Raz, they had them in fiat 126's, and I have an immaculate spare one
RazMan
| posted on 28/5/07 at 01:12 PM |
That's a kind thought NS Dev but won't that mean a complete rethink in my column mountings, switchgear etc? Or have I got the wrong end of
the stick?
Raz
NS Dev
| posted on 28/5/07 at 04:39 PM |
yea will be a rethink in terms of switchgear i'm afraid.
I think for your situation, just get somebody to turn up a suitable phosphor bronze top hat bush with a circlip groove the other side to the hat rim
and clip it in where the plastic one came out.
RazMan
| posted on 28/5/07 at 09:36 PM |
Excellent idea - especially about the circlip
Raz
