scoobyis2cool
posted on 14/8/03 at 12:07 AM |
Wishbone weld ridge
I'm currently trying to assemble my MK Indy suspension but the inside of the wishbone tubes have a ridge where they are attached to the wishbone
arms and this is making it difficult to get the bushes in. Should i remove this or can i push the bushes in with a vice? If i remove them will it
affect the strength of the wishbone?
posted on 14/8/03 at 12:28 AM |
It's the seam in the tube. General concensus is that it helps to lock the bush in place but if you can't get them in file it down a bit
and loctite them.
yours, Pete.
