dpavlov
| posted on 19/6/07 at 06:36 PM |
caliper piston
I´m having trouble finding replacement caliper piston for sierra front calipers. Can I make one myself as it looks just simple lathe work? Stainless
maybe?
mistergrumpy
| posted on 19/6/07 at 07:01 PM |
Try here mate. Sorted me out no problems.
mark chandler
| posted on 19/6/07 at 07:07 PM |
yes you can lathe one up, stainless is fine infact an upgrade if you are refurbing landrover calipers.
You will need to get a good finish.
Bluemoon
| posted on 20/6/07 at 08:10 AM |
biggred pistons are SS machine up on a lathe... Like said depends if you can get a good finish, then you can do em yourself.. The biggred pistons I
have just fitted had a good finish but I did carefully ploish the machine marks out with some scotch bright (moving along the machine lines NOT
across!)..
Dan
[Edited on 20/6/07 by Bluemoon]
ruudbeckers
| posted on 20/6/07 at 03:10 PM |
The bigg red ones are 12 pounds each. However, I have bought some reconditioned calipers from autoware13 on ebay, they are 30 pounds each. He does not
have them listed on ebay, but you can send him a message.
dpavlov
| posted on 21/6/07 at 05:31 PM |
a already talked to a guy on CNC lathe at my work and he says he can achieve almost mirror like finish, and can turn them in no time. and it would
cost me only a beer or two.
dpavlov
| posted on 30/7/07 at 07:42 PM |
Here they are. Machined from stainless steel. Now i can finally put calipers together.
[Edited on 30/7/07 by dpavlov]
dpavlov
| posted on 30/7/07 at 07:45 PM |
lathe turning
