Author: Subject: bush into bracket
oadamo
posted on 21/6/07 at 08:10 PM Reply With Quote
bush into bracket
the bushes i have dont fit the brackets what do you use to pack them out just normal washers. i thought that they had to clamp the inner bit. but with the washers there wont it let them move.
adam
flak monkey
posted on 21/6/07 at 08:12 PM Reply With Quote
Turned spacers, or find some tube with the right ID/OD.
Sera
http://www.motosera.com
ReMan
posted on 21/6/07 at 08:16 PM Reply With Quote
Washers no bigger than the bush.
Very hard to find so you prob need to get some turned.
t.j.
posted on 21/6/07 at 08:26 PM Reply With Quote
what do you mean with "turned" any pic?
ReMan
posted on 21/6/07 at 08:41 PM Reply With Quote
flange nut
posted on 21/6/07 at 08:48 PM Reply With Quote
You can get large stainless 12mm id repair or mudguard washers that are about the right od for the bushes.
Geoff
t.j.
posted on 22/6/07 at 03:15 AM Reply With Quote
I'm gonna use washers OD 24 mm 12mm ID and 2 mm thick.
They are fine for the job and plenty available.
grtz
