ever88
posted on 20/7/07 at 09:50 PM |
camber castor kpi
hi
I would really like to hear other people advice on this if they have the time.
I understand that the cortina has 4.4 degrees of KPI which is a little low and have searched through threads about what castor to run etc but my
project involves lifting an old ford shell over top of locost chassis and using a engine up front which is perhaps 25% heavier than a zeetec.
my question is what castor and camber would you set the wishbones to seen as the KPI part is fixed. a drawing of wishbone position here if have one
would be great.
sincere thanks to those who input
blakep82
posted on 20/7/07 at 10:23 PM |
quote: Originally posted by ever88
my project involves lifting an old ford shell over top of locost chassis and using a engine up front which is perhaps 25% heavier than a zeetec.
intruiging! what shell are you going to use?
________________________
nitram38
posted on 21/7/07 at 08:00 AM |
It is not the kpi that is too low, it is your wheel offset that is probably wrong.
If you draw a line through kpi it should intersect a point on the ground as close to the centre of your tyre.
kpi is primarilary there to reduce tyre scrub. It also tips the wheel into a turn but this is a secondary benefit.
If your kpi is wrong, when you make tight turns, you literally drag the outside wheel instead of having it roll.
