Author: Subject: Whats heaviest, solid/vented?
gr8ging
posted on 21/7/07 at 11:09 AM Reply With Quote
Can anyone tell me what brake discs to use.
It has been suggested to me that solid discs would be lighter, is this the case?
I'm using a zx9 engine which I am told may lack a little in low down torque so would like to keep weight down without braking the bank!
sorry for all the questions but I'd rather do the research then jump in and buy the first thing I see. And you guy's seem to have all the answers
Weaseling out of things is what separates us from the animals.... except the weasel.
You couldn't fool your own mother on the foolingest day of your life with an electrified fooling machine!
iiyama
posted on 21/7/07 at 11:22 AM Reply With Quote
Solid will be a lot lighter then vented for the same given diameter of disc. Using 283mm X 9mm on mine. Only need to go vented for heavier/faster cars really, lots more energy stored = lots more heat produced on stopping
If its broke, fix it. If it aint broke, take it apart and find out how it works!
posted on 21/7/07 at 12:02 PM Reply With Quote
On a 7 standard discs are fine, uprated pads can be useful.
Vented discs are just heavier, drilled discs tend to fracture (not good!), grooved discs tend to wear away pads quicker.....
I'd stick with standard....
RazMan
posted on 21/7/07 at 01:43 PM Reply With Quote
Vented discs are completely unneccessary on a light car imo. They can be nearly twice as heavy as a solid disc and the extra cooling will never be needed except under extreme race conditions.
If you are looking to improve the braking then try changing the pads to a better compound, but watch out for WORSE braking when they are cold. Standard pads are more than adequate for a road car.
Raz
