tks
| posted on 27/7/07 at 11:53 AM |
Driveshaft NUTS part number
Is there a shop/online place where they sell them new??
need to change then and one nut is not reusable also i thought they wheren't reusable.
does anyone know the part number?
Tks
[Edited on 27/7/07 by tks]
| posted on 27/7/07 at 12:04 PM |
A Ford dealer might be your best bet
tks
| posted on 27/7/07 at 12:05 PM |
does anyone have the part number?
or a link to those 'fiches'
Tks
jabbahutt
| posted on 27/7/07 at 12:31 PM |
hope this helps
Green insert 41mm nut 6133 688 £4.48
White insert 41mm nut 6133 689 £4.48
these are push in drive shafts of a 2.0 Pinto Sierra, I don't know if the bolt in types need a different number
tks
| posted on 27/7/07 at 12:34 PM |
to confirm this are the HUB nuts right?
The nut wich you place at the end of the driveshaft and torqued up to 250nm right??
are those the side colors? White means normal thread and green means lefthand thread?
thanxs in advance..
Tks
jabbahutt
| posted on 27/7/07 at 01:51 PM |
yes these are the in famous 250lbs hub nuts. The colour refers to the colour of the nylok insert, sorry I can't remember which colour is the
left hand thread but you'll soon find out when you come to fit them.
hope this helps
[Edited on 27/7/07 by jabbahutt]
tks
| posted on 27/7/07 at 01:59 PM |
okey thanxs
now i hope your numbers are ok...
since some other parts from FORD had much longer numbers.
Tks
tks
| posted on 27/7/07 at 02:05 PM |
quote: Originally posted by jabbahutt
hope this helps
Have looked at the nuts..
White = irregular thread
Green = regular thread
Tks
jabbahutt
| posted on 27/7/07 at 02:56 PM |
you're more than welcome
matt_gsxr
| posted on 27/7/07 at 04:02 PM |
tripod and lobro (i.e. push in, and bolt on) have nuts that are interchangeable.
Matt
