Cheffy
| posted on 28/7/07 at 04:49 PM |
Position of lower steering column bush
Do you reckon this is okay for the positioning of my lower steering column bush - ie. is it too high up or too low down the column? I'm thinking
mainly in terms of having enough room to allow the column to 'crush' in the event of a frontal impact. Also to keep Mr SVA happy as well of
course.
  Steering column lower bush
TIA,
Mart.
Farts are like Rock'n'Roll. You love your own but you hate everybody else's. Lemmy, Motorhead.
| posted on 28/7/07 at 05:58 PM |
It shouldn't make any difference as the triangular section will slide through the bush, but have you checked where the steering wheel is in
proportion to your seating position. The outer column looks a lot further forward than mine
Cheffy
| posted on 28/7/07 at 06:18 PM |
Hi Pete,
Thanks for the response. I just wondered whether the part lower part of column had enough room to travel back up into the upper part of the column
before the triangular bracket (joining the upper to the lower part of the column) fouled on the bracket - er - if you see what I mean!
The reason it looks further forward is because the cross member it's mounted to is further back than usual. You can just see where it was
originally mounted before I moved it back to give me a little more room to move the engine back. I'm using a V8 and inboard front shocks and
space was a little tight in front of the engine!
Mart.
| posted on 28/7/07 at 06:33 PM |
If you still have the collapsible section at the top of the column, the concertina metal part and a 10º angle between your upper column and the
steering rack connection you should be o.k.
paulf
| posted on 28/7/07 at 08:33 PM |
Mines mounted in the same place , had no problems at SVA.The only problem I have found is that the single bush doesnt support the column very well
and allows some movement.I was worried about it as just put the car through its first MOT but they were happy with the slight play.
Paul.
Avoneer
| posted on 28/7/07 at 09:09 PM |
Mine's about there too.
Seem like the normal place on most cars, or just under the chassis bar for those with higher chassis like MK's and the Avon.
Pat...
Cheffy
| posted on 29/7/07 at 08:33 AM |
Great, thanks guys.
Mart.
big_wasa
| posted on 29/7/07 at 08:42 AM |
mines about the same
geoff shep
| posted on 30/7/07 at 12:30 PM |
Is this Sierra stuff? Is it me - or is Cheffy's bush (!) the wrong way round? And bigW, which way is that spring washer thing on yours -
can't see clearly from the photo? I thought it all went together like this:
Cheffy
| posted on 31/7/07 at 12:37 PM |
The bush is new but I just put it on the same way the old one came off.
Would be interested in what others think though - I suppose it 's possible that the one I took off had been put on the wrong way round.
Mart.
[Edited on 31/7/07 by Cheffy]
geoff shep
| posted on 7/8/07 at 07:17 PM |
Can't see it in great detail but there's a pic on this 'for sale' ad
http://www.locostbuilders.co.uk/viewthread.php?tid=71794&page=&contribmessage=none
Cheffy
| posted on 8/8/07 at 08:50 AM |
Hi Geoff,
Yep, I think you're right mate. I'll turn mine round forthwith!
Martin.
