8smokingbarrels
| posted on 1/9/03 at 06:11 PM |
Sierra rear calibers
Can anyone tell me whereabouts the sierra rear disc caliber is mounted- is it rear or front. The granada's is above the disc that i do know
Thx for any help
chris
jcduroc
| posted on 1/9/03 at 08:15 PM |
Same for Sierra
Joćo
Viper
| posted on 1/9/03 at 09:31 PM |
Of course it doesn't have to go on top..
ChrisW
| posted on 2/9/03 at 07:48 AM |
The mounting for the hub is square so you can choose any position you want, subject to being able to get the hand brake cable out.
Chris
My gaff my rules
bob
| posted on 2/9/03 at 05:56 PM |
BUT BEWARE
You may get an air lock when bleeding the caliper if moved to a different possition,mine are to the rear of the hub and i had to remove the caliper to
bleed properly.
Viper
| posted on 2/9/03 at 06:39 PM |
bleed properly.
Is that because you have the calipers on upside down?
Stu16v
| posted on 2/9/03 at 08:47 PM |
Nope. Even if it is side mounted, and the bleed nipple looks to be at the highest point, unfortunately the drilling to the bleed nipple isnt. Result
is that you end up with a trapped pocket of air in the caliper(s).
Viper
| posted on 2/9/03 at 09:11 PM |
TVR use the sierra caliper on the rear of the upright....
Don't have to take them off the car o bleed them...
bob
| posted on 2/9/03 at 09:36 PM |
Siearra caliper
Tim
Tried up both ways and still had the same effect(air pocket)so very spongy on the pedal.
Easy enough to bleed though as i just unbolted caliper and roled it round the disk to 12 o-clock and bled.
Viper
| posted on 2/9/03 at 09:48 PM |
Mine are as yours, ish, i haven't bled them yet, TVR chimera,griff are the same and i have never had any problems bleeding them??
bob
| posted on 2/9/03 at 09:58 PM |
TIM
Couldnt get any definate pressure pad to disc at 1st when i bled them in this position,but as soon as i rolled them around the disc all works fine.
Thought it was me at 1st but someone else had the same prob and advised me to bleed caliper off the mounting point.
Anyhow all is well now.:
Viper
| posted on 2/9/03 at 10:04 PM |
Next time i talk to the factory (TVR) i will have to ask if they do any mods to the calipers to overcome this...
8smokingbarrels
| posted on 4/9/03 at 01:56 PM |
Thx for all the info guys
I assume the reason u all have moved the caliber from the top position is to avoid it interfering with the upper wishbone- am i right?
Thx
chris
bob
| posted on 4/9/03 at 02:04 PM |
not so much avoiding the top wishbone,its the hub carrier thats the problem. And also the handbrake cable travel/route,there are more pics on my
archive of the hub and hub carrier.
8smokingbarrels
| posted on 12/9/03 at 08:23 PM |
Thx Bob
Your 'rear hubs' pic explains things very well to me- I assume you have moved the hub 90 degrees to allow the caliper to be mounted
rearwards (from being on top).
Have you had any clearance problems with the handbrake cable and the driveshaft itself?
Thx
chris
bob
| posted on 14/9/03 at 07:33 PM |
Chris
MK designed it this way and it seems to work fine,the handbake cable of which i thought was going to be a prob turned out ok and i'm happy with
the route and travel of the cable.
You may well find that others have routed there cable different to mine though,i'm sure there are some pics in the archive of other MK and Luego
rear set ups with discs.
I looked at a few variations and sort of made mine go in an S shape towards the rear panel then back to the fuel tank and finally into the tunnel.
