chrisg
| posted on 22/8/07 at 12:56 PM |
Top upright joint on a rocking arm suspension.
Hey Up
I've been designing a top rocking arm front suspension and I had been intending to use the old Transit draglink end.
I've been having doubts because of the extra load imposed transfering the spring/damper loads through the joint.
Do you chaps think that a switch to a bolt on type joint which can be backed up with a plate is necessary?
All comments welcomed
Chris
[Edited on 22/8/07 by chrisg]
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
MikeR
| posted on 22/8/07 at 01:12 PM |
I have a vague memory of this conversation from a long time ago. Consensus then was it wasn't up to the job. Personally i haven't a clue
procomp
| posted on 22/8/07 at 01:16 PM |
Hi reaserch on the raw striker setup would be a good start.
But the trouble is that no one as yet has managed to get this setup to work properly and last any real lenght of time without issues arrising. Inc
raw.
cheers matt
bob
| posted on 22/8/07 at 01:19 PM |
Wasnt this a big topic on one of the cobra forums a while back, i seem to remember the bmw based cobra having the drag links or similar and getting a
right slating.
Although this car was linked to limelight/filby so it was never going to get good praise but thats another story.
clockwork
| posted on 22/8/07 at 01:30 PM |
Sylva phoenix has rocker arm front suspension...
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
clockwork
| posted on 22/8/07 at 01:34 PM |
As does the R1ot for that matter.
andyps
| posted on 22/8/07 at 01:42 PM |
The stryker uses a Metro ball joint and seems pretty well set up to me - have a look at the times recorded by Strykers when competing against other
cars with similar engines in hillclimbs and sprints and they have to be good.
I'm using the Transit link unless someone convinces me otherwise!
| posted on 22/8/07 at 01:47 PM |
A proper ball joint is required ideally one designed for push in loads --- Maxi, Mini spring to mind.
With this setup you might want to consider a different method of camber adjustment.
matt_gsxr
| posted on 22/8/07 at 02:11 PM |
I know this has been mentioned...
but this may be more explicite!
Striker/Phoenix
METRO (late) -Top wishbone knuckle joints (for rocker arms).
Matt
mookaloid
| posted on 22/8/07 at 02:22 PM |
I would have thought that the threaded portion of the transit draglink end would be an ideal site for fatigue cracking as it is subjected to repeated
and large amounts of bending force.
So not only not ideal but an accident waiting to happen IMHO
mark
indykid
| posted on 22/8/07 at 03:38 PM |
what about something like the joints dax use on the top wishbone? can't remember whether it's on the tojeiro or the rush
the bolts are perpendicular to the balljoint taper, so you can adjust camber with shims.
there may be nothing suitable in such a format, but just thought i'd throw it in.
tom
chrisg
| posted on 22/8/07 at 03:54 PM |
Thanks for the replies chaps.
It was the sideways stress on the threaded part that worried me.
I have a contact at Dax, I'll give him a ring.
Re camber alteration would slotted holes with some sort of locking device do this?
Chris
chrisg
| posted on 22/8/07 at 04:09 PM |
I've just rooted out this picture from stoneleigh.
This set-up looks pretty good, anyone any idea where that joint is from?
Chris
Liam
| posted on 22/8/07 at 04:42 PM |
That's a dax top joint - not sure what it's from but they'll be able to tell you. I'm using maxi joints on my setup.
Liam
chrisg
| posted on 22/8/07 at 04:55 PM |
Yeah I know, it's from the Tojerio, camber compensation set up.
Just don't know where the BJ is from!
Chris
40inches
| posted on 22/8/07 at 05:07 PM |
Chris
Jaguar XJ6 around 1993
OK! make that 1995-97 http://www.autopartswarehouse.com/replacement_sm/jaguar~ball_joint~replacement.html
[Edited on 22-8-07 by 40inches]
jack trolley
| posted on 22/8/07 at 05:08 PM |
The Tojero (Cobra) uses Jag IRS & IFS.
Obviously the top wishbone is fabricated for the camber compensation set up, but
the rest are probably Jag parts.
iank
| posted on 22/8/07 at 05:13 PM |
If it's a Jag part it should be pretty rebust
Anonymous
chrisg
| posted on 22/8/07 at 05:29 PM |
god bless you - I'll get one tomorrow!
Chris
40inches
| posted on 22/8/07 at 05:38 PM |
Used Just Jags before,very good service http://www.justjagsuk.com/shopdisplayproducts.asp?Search=Yes
| posted on 22/8/07 at 05:46 PM |
Apart from the strength of the threaded part of the drag link, the other reason not to use it is that the ball joint is spring loaded in order to
eliminate any play as it wears. By putting loads verticaly into the balljoint, the spring will be compressed and you will end up with a floppy ball
joint.
mark chandler
| posted on 22/8/07 at 10:38 PM |
David Manners for me when asking for Jag bits
linky thing
They list a lower ball joint on the front suspension as CAC9937, its £20.56 with VAT. Although its years since I had a jag it does look familiar.
Regards Mark
Regards Mark
chrisg
| posted on 22/8/07 at 10:51 PM |
I think it's the upper one CAC9938?
cheers
Chris
| posted on 23/8/07 at 09:56 AM |
Are they spring loaded Mike? Bottom ball joints on metro etc are but these are top joints and are track rod ( drag link) ends which don't
usually have springs. Has anyone destroyed one so we can check inside?
| posted on 23/8/07 at 06:06 PM |
Chris
1960s-90s Jag XJ6 -- part -- not designed for spring loads
Triumphs and SAAB 99 also use something similar.
The SAAB one is designed for push in balljoint loads as is the Triumph Dolomite one.
