greggors84
posted on 10/9/03 at 12:50 PM |
ABS Hub in a Non ABS upright
Will my abs hub with the splined bit for the sensor fit ok in a non abs upright. I need to get a new upright and i cant get an ABS one for ages so i
was wondering if the hub and upright would go together ok.
Chris
The Magnificent 7!
ned
posted on 10/9/03 at 01:32 PM |
are you talking sierra front into sierra upright or sierra rear into MK upright?
Ned.
beware, I've got yellow skin
zetec
posted on 10/9/03 at 02:14 PM |
If you are talking about the rear one I had the same problem. MKs answer was to have the grooved section removed either with a file or turned off on a
lathe and then they fit. Normal ones dont have the same problem. Give MK a ring to check if still the case.
blueshift
posted on 10/9/03 at 03:08 PM |
Greggors, don't suppose a 4x4 ABS upright would be any use to you would it? we'll have a couple of those with no home to go to soon.
greggors84
posted on 10/9/03 at 09:24 PM |
No i mean front
Chris
The Magnificent 7!
blueshift
posted on 11/9/03 at 12:14 AM |
I assmed you meant fronts. we only want the back bits or our sierra, front uprights are surplus to requirements.
that's why I dunno if 4x4 are any good to you, maybe you could retrofit the stub axle into them or something?
shout if you want em anyway
[Edited on 11/9/03 by blueshift]
