vorn
| posted on 11/9/07 at 10:26 AM |
top shock mounts
Hi everyone.
I have been looking at my top shock mounts, how do you have yours mounted ? on the side of the top rail or the bottom of the top rail.
If I mount the shock on the side I can get less angle on the shock , which I believe is better .
If I have it on the side I think it would not be as strong as mounting on underside of the top rail.
[Edited on 11/9/07 by vorn]
vorn
| posted on 11/9/07 at 10:28 AM |
otherside
clockwork
| posted on 11/9/07 at 11:37 AM |
Side. Strength is not an issue.
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety." Benjamin Franklin.
"Well if you have nothing to hide, you have nothing to fear" Morons the world over.
Locost/Kit builders info and FAQ website:- www.carbuilders.info
MikeR
| posted on 11/9/07 at 12:49 PM |
I did bottom as i was worried about introducing a twist in the shock by putting it on the side and not getting the mount parallel to the mount on the
wishbone.
Side is better as the shock is more vertical and its how most people do it.
big_wasa
| posted on 11/9/07 at 03:15 PM |
mine are on the bottom due to top bone clearance
Avoneer
| posted on 11/9/07 at 07:48 PM |
Apparantly, the steeper the shock angle the better, so with your top bones, you should be able to get them on the sides.
I put mine on the bottom though and my car works fine and personanly, I think they look neater on the bottom.
Pat...
vorn
| posted on 11/9/07 at 08:48 PM |
Thanks guys , I think I will mount them on the side to get better shock angle
