jimbona2
| posted on 19/9/07 at 11:14 AM |
do you really need to sand down the uprights for avon?
I fittered my uprights, brake plates on last weekend without sanding the uprights down, as shown in this photo? do you really need to do this? mine
seem to fit okay?
(photo taken from avon-kitcar.co.uk)
thanks
melly-g
| posted on 19/9/07 at 12:15 PM |
I don`t remember having to do that on mine!!
tks
| posted on 19/9/07 at 03:18 PM |
obviously it will depend on the brake setup wich is choosen on the rear.
maybe its for wilwoods nececary but not for standard sierra.
Tks
Avoneer
| posted on 19/9/07 at 04:20 PM |
Have you tried fitting the back plate?
I think it was the opposite corners that needed grinding off.
Why would you need to sand them down?
Pat...
timwest167
| posted on 19/9/07 at 05:03 PM |
Think it depends upon what donor the rear brakes came off. I can't remember whether my drums were the larger or smaller sierra ones, but I
didn't have to grind anything off. If yours appear to fit with no fouling, go for it.....
t.j.
| posted on 19/9/07 at 07:01 PM |
I made a upright and had to grind them.
It's is that the back-plate for drum-brakes don't fit.
Grtz
Avoneer
| posted on 19/9/07 at 07:47 PM |
Did you get the plates to fit after all the woes in your previous post?
Pat...
