Author: Subject: 3-way connector issue
Findlay234
posted on 12/10/07 at 04:46 PM Reply With Quote
Ive tried to bleed my brakes and found that the 3way unions on the front and the back both leak. Ive started off by tightening them, failed, re-doing the pipe flarings, also failed. then i had a look into the union itself and noticed that the end in concave instead of being convex like the tip of my flexi hoses and the master cylinders. Therefore the flaring has nothing to wrap around. Is this correct or should there be convex ends to the 3way union?
any help appreciated.
Alex B
posted on 12/10/07 at 05:04 PM Reply With Quote
Get a mate to make a new pipe up or put a double flare in if you have room on the length.
Alex
Alex B
posted on 12/10/07 at 05:07 PM Reply With Quote
Does this help?http://www.integerspin.co.uk/brakeflare.htm No cos it don`t click
[Edited on 12/10/07 by Alex B]
907
posted on 12/10/07 at 05:17 PM Reply With Quote
Hi.
I fitted a tee to my system that I bought separately from the local Ford garage.
After remaking the flared ends on my copper pipes (twice) it dawned on me that the threads were bottoming before the flairs were crushed.
I sanded 2mm off the tee ends and refitted the pipes and they were fine, a thread to spare on the male fitting.
It maybe worth checking.
hth
Paul G
iank
posted on 12/10/07 at 05:27 PM Reply With Quote
Anonymous
Alex B
posted on 12/10/07 at 05:37 PM Reply With Quote
Thanks Iank. Paul I did the same and also put a larger flare one behind the other. It was that long ago I noticed one of my TRE is perished and the car aint moved yet.
Alex
posted on 12/10/07 at 06:13 PM Reply With Quote
Before too much more misinformation gets posted this is the situation.
In this case what is wrong the wrong tube nuts have been used metric male tube nuts come in two lengths for the Tee connection the longer type is required.
See http://www.vehicle-wiring-products.eu/VWP-onlinestore/brakepipe/brakes.php
Standard metric flare for a male tube nut fitting is a single flare eg. convex.
Standard metric flare for a female tube nut is a double flare eg convex+concave.
Exception exist to this rule but usually only in specific cases for example For example Escort live rear axles on which both rear brakes are bled through one bleed nipple.
[Edited on 12/10/07 by britishtrident] Rescued attachment B620-2.gif
Alex B
posted on 12/10/07 at 07:08 PM Reply With Quote
Thanks Andy . Did you get my u2u or are you no peekin?
Alex
