Author: Subject: capri C.W.P
phil
posted on 20/9/03 at 07:28 PM Reply With Quote
capri C.W.P
Question for all you Ford boys,
Will a 3.0 capri crownwheel & pinion fit a mk 5 cortina axle ??????
cheers
phil....
Nick Davison
posted on 22/9/03 at 04:12 PM Reply With Quote
What final drive ration is that?
phil
posted on 22/9/03 at 08:12 PM Reply With Quote
3.09:1
Nick Davison
posted on 23/9/03 at 09:29 AM Reply With Quote
What other gearing are you using that with as it will need a fair amount of power to give the acceleration?
Nick
phil
posted on 23/9/03 at 06:48 PM Reply With Quote
Hi Nick,
my engine is a citroen diesel tdi, running through an FSO polonez diesel gear box. Using a gear calculation program, a final drive ratio of 3:10 and running on 14" wheels would give me about the same performance and economy of the BX donor. At present i have a escort axle fitted but the highest diff ratio seems to be 3.45:1 which is a bit on the low side.
cheers phil.......
